FI virgin, critique my wastegate and BOV
Old 04-24-2008, 10:01 AM
dhdenney's Avatar
Default FI virgin, critique my wastegate and BOV
Single 80mm turbo, 6.0 iron block, 700+ hp. Looking at single 46mm wastegate and 50mm BOV based on my reading here. Low boost is not a goal. Would a gate for each bank be necessary?
Old 04-24-2008, 10:23 AM
Fireball's Avatar
Personally, I'd run a bigger gate. Single should be fine. I'm using a single 60mm on my car which originally started as a GT47-based setup
Old 04-24-2008, 10:37 AM
LS1TECH Sponsor
DrTurbo's Avatar
I would go 50mm wg and 56mm BOV.
Old 04-24-2008, 10:38 AM
70Stang's Avatar
I would run one single 48mm (Turbosmart ProGate) and the one 50mm BOV will work great. You don't need a big gate if you don't need low boost so a 48 would be perfect.
Old 04-24-2008, 10:45 AM
dhdenney's Avatar
Thanks guys. Looks like I found a good range to go with. I guess as long as I have at least a 50mm range on both I should be good to go. Just gotta finish buying parts and get the biotch put together.
Old 04-24-2008, 11:10 AM
Derek @ EDO's Avatar
I would run the
JGS500 50mm Wastegate
JGS 560 Blow Off Valve
TOP NOTCH STUFF!
I believe you can get them from Dr.Turbo @ forced inductions.
Old 04-24-2008, 11:27 AM
dhdenney's Avatar
I'll see what I can find on Fleabay or the classifieds since I have a little time.
Quick Reply: FI virgin, critique my wastegate and BOV
