Please help me with a few turbo questions
Old 04-25-2008, 07:01 PM
01SSKilla's Avatar
Default Please help me with a few turbo questions
I'm building a 370 iron block to use with a turbo. 11cc dish pistons with unmilled 317s should give me a 9:1 CR. Pistons and rods will be forged. I will be building the kit myself with truck manifolds and I have a few questions. Looking for around 700 to the wheels and I will be driving it on the street as well as the track.
1) Would a 76mm be too small? Is an 88 a better match?
2) What size BOV would be sufficient?
3) Wastegate size?
4) Would it be a bad idea to use the stock MAF or should it handle the extra airflow?
5) How far should the BOV be from the TB?
Old 04-25-2008, 07:40 PM
borninatransam's Avatar
1) you can hit 700 with a 76mm. Check out www.forcedinductions.com for a good selection.
2)Tial 50mm BOV would be my choice. Price is going to be around $250 and dont buy an ebay knock off.
3)Tial 38mm wastegate should be good.
4)If it were me id have it tuned speed density.
Old 04-25-2008, 08:04 PM
01SSKilla's Avatar
Is 700 going to be close to the max though?
38mm wastegate sounds kinds small compared to what I've seen a lot of people run on here.
With speed density you just get rid of the MAF?
Old 04-25-2008, 11:40 PM
XpEdItIoUs's Avatar
Depends what 76 you go with. With A speed density tune you don't need a maf.
Old 04-25-2008, 11:41 PM
XpEdItIoUs's Avatar
Get your turbo from forcedinductions.com and ask jose what turbo would work best with your engine setup.
Quick Reply: Please help me with a few turbo questions
