Who is running ls7 mls head gasket on their afr 225 72cc heads?
Old 04-30-2008, 08:19 AM
MY99TAWS6's Avatar
Default Who is running ls7 mls head gasket on their afr 225 72cc heads?
Need to pick some head gaskets right away.Its either cometic or the ls7 mls ones. Part number which I assume is correct is 12582179.Anyone running these on their afr and how are they working out? Still worried if go cometic will have to do more block or head prep. Should I copper spray the ls7 gaskets ??
Old 04-30-2008, 10:31 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I am running LS7 gaskets on mine. No problems here
Old 04-30-2008, 11:25 AM
MY99TAWS6's Avatar
Hmm someone posted the coolant passages didn't line up with 6.0 block. Anyone running ls7 gaskets with iron block build with afr 225 72cc heads???
Old 04-30-2008, 11:58 AM
veee8's Avatar
Very interested too!!! Mine are already installed, but haven't started yet. I don't remember anything being out of whack.
Old 04-30-2008, 05:41 PM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
ls7's here
Old 04-30-2008, 06:40 PM
MY99TAWS6's Avatar
Ok red 6.0 iron or something else? The question now is will the ls7 head gaskets work on 6.0 iron engines with the afr 225s since read one guy say the coolant passages didn't match up?
Old 04-30-2008, 06:48 PM
red83's Avatar
ive got 6.0 iron block and 225cc afrs. i have not run it yet, but the coolant passages all looked the same. some one else chime in if they are different
i havent heard of the cooling passages not lining up. if that was the case the heads would be different also and wouldnt be able to interchange.
Old 04-30-2008, 07:29 PM
veee8's Avatar
I'm all freaked out now! But I don't recall seeing any differences. But now I am second guessing. Anyone else have any first hand experience with this? Kurt @ W2W???
Old 04-30-2008, 08:04 PM
red83's Avatar
https://ls1tech.com/forums/showthrea...skets+head+ls7
look at post 20. those passages look identical to the passages that are in my 7.0l head gasket. (i have an extra one that i compressed wrapped in plastic)
Attached Thumbnails Who is running ls7 mls head gasket on their afr 225 72cc heads?-img_0224.jpg
Old 04-30-2008, 08:38 PM
veee8's Avatar
Yeah looks pretty close to me. Whats up with Tooley??? Got me all worked up!
Old 04-30-2008, 08:41 PM
veee8's Avatar
Of course studying it a little closer, the hole directly above the lower studs looks a little higher???
Old 05-01-2008, 06:23 AM
red83's Avatar
i dont think it is higher. i think it looks higher because of the bigger bore in the ls7 gasket.
if you look real close to the odd shaped water holes on the end of the gasket you will notice a slightly different shape. but they will be fine.
Quick Reply: Who is running ls7 mls head gasket on their afr 225 72cc heads?
