4l80e and turbo car
Old 05-02-2008, 07:40 PM
trans2000am's Avatar
Default 4l80e and turbo car
ive searched and searched trying to find out what the power level is with a stock 4l80e. im confused some say 550 some say almost 700.
i dont wanna keep rebuilding my 4l60e eveytime something breaks.
has anybody ran a stock 4l80e on FI appl. how long did it last and how much hp and tq?
also can i use stock converter?
my car is not gonna be a track car only a couple times a month. I would like OD never driven in turbo400 so i dont know how they feel and if they can be driven on the street with out be annoying.
this is probably the hardest decision to make
my goal is 800 to the wheels.
Old 05-02-2008, 08:33 PM
30th t/a's Avatar
I asked this question also. 500rwhp is about the max to put to it and still live. I definatley would not put 700-800 to a stock 4L80e and expect it to live long. the stock convertor is also weak for the power you want. I went with a Yank SC3000. I hear that these are very tight converters and are very strong.
Old 05-02-2008, 08:59 PM
jamnut's Avatar
It doesn't take much for someone that knows how to build 80's to make them stout enough to easily handle 800 rwhp. They are getting cheaper every day too.
Old 05-02-2008, 09:52 PM
camarols1's Avatar
Give Chuck a call at Finish Line, he can steer you in the right direction.
800HP to the ground will require a purpose built trans for sure.
Old 05-03-2008, 05:05 PM
ok then why does like FLT 4l80e go for like 3,300 dollars? what does it include
by the time i get a stall,harness,crossmember,tailshaft your talking 5000plus
Old 05-03-2008, 05:10 PM
what needs to be rebuilt on the 4l80e can i just install a overhaul kit and be good, im mean do you really have to have new cluthes,bands,input and out put shafts installed?
Old 05-03-2008, 05:11 PM
ZZebes's Avatar
Quality Quality Quality
Parish8 pushed his FLT to over 1k hp on a twin turbo setup on a FLT LevelV in a 4000lb truck
remember the 4l80e was designed to go behind a diesel (FI) with huge Torque numbers
us truck guys take them to 700hp on just a shift kit all day long and drag extended cabs into the 11's on stock stalls
Old 05-03-2008, 05:16 PM
ok so with just a basic overhaul kit which ive searched and it goes for 200 bucks then what can it handle?
i have no problem spending the money on a nice trans just dont wanna spent stupied money on items that isnt needed,you know what i mean.
Old 05-03-2008, 06:43 PM
HydroStream6's Avatar
Head over to the Automatic Transmission section of the forums and look at all the 4L80 info... there's guys running them over 700rwhp stock. All of the swap info is in there too.
Old 05-04-2008, 08:50 AM
30th t/a's Avatar
I took my 4L80e to a local, reputable transmission shop. I told him what Im doing with it and he told me $1150 and garunteed to handle 1000HP. The guy is good. Another Ls1tech member is running mid 9's NA with one of his built trannys.
Old 05-04-2008, 11:18 AM
Websy21's Avatar
This is what I did too along with a custom 3000 stall, TCI flexplate and all the swap parts. It has just finished being built and still at the shop however I might be selling it now. Upgraded eagel clutches, overhaul kit, etc, etc it was going to live behind 1000fwhp with no probs
Old 05-04-2008, 04:23 PM
calongo_SS's Avatar
I don't think it takes too much to make an 80 stout. I had mine built with red clutches, kolene steels, and replaced all the seals and bushings. I spend about $700 total on parts and labor to rebuild it locally. No point in spending a boat load of money unless you are shooting for > 1000 hp.
Quick Reply: 4l80e and turbo car
