just a little teaser
Old 05-03-2008, 10:14 PM
LS1IMPULSE's Avatar
Default just a little teaser
I got a call from the machine shop and my billet main caps are installed and the block is ready to be picked up, then I got home to my EPP order (big thanks!, these guys dont mess around, once I placed my order they had it balanced and here in no time!)
Old 05-03-2008, 11:38 PM
Websy21's Avatar
**** teaser, LOL
Looks like fun!
ninetres's Avatar
Huh? How are your main caps installed if you came home to your crankshaft in a box?????
Old 05-03-2008, 11:42 PM
jmill96Z's Avatar
That looks like one helluva build. Continue to keep us informed when progress is made
Old 05-03-2008, 11:51 PM
BoostnTBSS's Avatar
I think he meant they were checked/lined honed you cant just bolt on new mains with out checking first...
Old 05-04-2008, 12:08 AM
LS1IMPULSE's Avatar
yessir, they were put on and honed to spec. I am doing all the other machine work I just dont have main bore equip. Now I just gotta find some time, finals week is so busy!!!
Old 05-04-2008, 12:34 AM
bluecamaroz28's Avatar
What's your plan?
Good luck with the build.
Old 05-04-2008, 12:37 AM
cws T/A's Avatar
Where the caps doweled ? What brand caps ?
What machine shop did you use and how much did the machine work cost you ?
Old 05-04-2008, 01:16 AM
LS1IMPULSE's Avatar
Originally Posted by bluecamaroz28
What's your plan?
to hit 1k to the wheels on the dyno ha. but seriously to have a 700HP everyday street car. Ill be using an ST80 kit from Josh @ Kentucky Turbo
Weston Machine in Piscataway NJ, they charged 400 for the caps and 380 for the install (bore/hone/minor machining to thrust area) I did not have the caps pinned and they came from Weston (the callies/W2W caps were backorderd for and unkown amount of time and W2W recommended Weston to me)
Old 05-05-2008, 07:59 AM
Dumb Ass Vette Moderator
ls1290's Avatar
My thinking. If the crankshaft was balanced, why are the rings not installed on the pistons and the rob bearing installed in the rods? Both are important to the overall balance of the rotating assembly.
Keith
Old 05-05-2008, 09:19 PM
LS1IMPULSE's Avatar
Keith
Not sure, the plastic bags the rings were in had been opened though and the rod bearing were not sealed to start with however I would imagine EPP knows what they're doing.
Old 05-06-2008, 04:08 PM
Jake@EPP's Avatar
Exactly, everything is very tediously weighed out to spec, nothing gets over looked in this area.
Quick Reply: just a little teaser
