Manifold gaskets - rtv or no?
Old 05-11-2008, 03:32 PM
FastBlackTA's Avatar
Default Manifold gaskets - rtv or no?
I reused a set of manifold gaskets on my vette to get it running so I'm swapping them out on wednesday (along with adding another methanol nozzle) so I can get off to the dyno.
Are you turbo guys running gaskets and if so, are you all using copper rtv on them?
Old 05-11-2008, 05:24 PM
stevieturbo's Avatar
You should never need sealer on any LS gasket.
Old 05-11-2008, 08:11 PM
badass99ss's Avatar
+1....I did use some on the corners of the timing cover to oil pan tho.
Old 05-11-2008, 08:23 PM
NemeSS's Avatar
ive never had to use sealer anywhere on the motor, as long as the silicone was intact on the aluminum gaskets
Old 05-11-2008, 09:19 PM
Should have clarified in my first post:
I have seen people use rtv on exhaust manifolds without gaskets....but was wondering if anybody uses it on the aluminum mls exhaust manifold gaskets.
Old 05-11-2008, 10:02 PM
Mr.MartyStone's Avatar
Yes, definitely ditch the gaskets and run RTV.
Old 05-11-2008, 10:54 PM
theblur98ss's Avatar
I always thought the stock metal gaskets were good. So you guys are just getting rid of them and smearing high temp rtv on the headers and bolting them down?
Old 05-11-2008, 11:44 PM
badass99ss's Avatar
I have never heard of using RTV instead of exhaust manifold gaskets ....I highly recommend Percy's xx carbon gaskets. They form/crush to fit, and I have never had an issue.
Troy
Old 05-12-2008, 12:47 AM
z06kilr's Avatar
Ive always use gasket and copper rtv on mine. never have leaks.
Old 05-12-2008, 03:03 AM
DanZ28's Avatar
never used rtv on the manifolds/headers, shouldn't need to or something is up.
Old 05-12-2008, 03:18 AM
lubsvitek's Avatar
I usually put some high temp copper rtv on exhaust gaskets and havent had any leaks. It'll prob burn off anyways but theres nothing worse than having an annoying exhaust leak and having to reassemble, so might as well.
Old 05-12-2008, 05:59 AM
Dumb Ass Vette Moderator
ls1290's Avatar
+1. They are designed not to need any.
Keith
Old 05-12-2008, 06:53 AM
Reject's Avatar
ok i'm stupid, what is LS gaskets? i know the multilayered gaskets but LS ?
...or are yall talking about LSx gaskets ?
aaarg to early and monday
Old 05-12-2008, 07:06 AM
Z06PSI's Avatar
Yes all gaskets for the LSX engines seal themselves as long as everything is set and torqued to spec. Always used dry here with no problems.
Old 05-12-2008, 07:10 AM
Reject's Avatar
yeah ok yeah i was trying to figure out what LS was standing for i kept going through different words to see if it would work and Loose Seals were the best i could get lol
Old 05-12-2008, 11:14 AM
Ever think the term "LS" might refer to an LS based engine ??
LS1, LS2, LS3, LS6, LS7 etc etc.....
Old 05-12-2008, 11:34 AM
Reject's Avatar
and a chevy truck option
Old 05-12-2008, 02:22 PM
Troy
Then you need to look at what all the real high hp guys are doing (yes there are other motors besides ls motors). It is very common to not use header gaskets and just use RTV. When you start making real power you'll have problems with traditional gaskets...especially just carbon gaskets. At the bare minimum run an aluminum gasket.
Marty
Old 05-12-2008, 02:30 PM
Marty
LS exhaust gaskets arent traditional crappy gaskets. If the stock exhaust manifold gaskets are leaking under boost, then you need the flanges machined flat.
Old 05-12-2008, 02:56 PM
alwaysinboost's Avatar
multi-layered stock metal gaskets with copper spray and I never had an issue.
Quick Reply: Manifold gaskets - rtv or no?
