STS Meth injection or FMIC Opinions
well soon here im going to be installing a sts kit on my Trans Am ill run 5 psi DD or 8 occasionally the kit i got came with the meth injection should i use the meth or since i got the FMIC i should be fine with it.. also dont forget i live in FL so it gets hot here but its not ganna see 8 psi in the day time tho so should i install the meth along with the FMIC or just the FM is fine?
1 Post
Should be fine with the FMIC. If you have both, never hurts to install both You'd want the meth when running 8PSI, even if it's only occasionally. Just my $0.02
Install both, you won't regret having the methanol available for your higher boost settings. Just make sure you've got a good wideband in the car, and have it tuned professionally.
Be sure to check out our special "black" series pump made by Shurflo. Our pump is engineered for use with 100% methanol.
http://www.alcoholinjectionsystems.com/images/methanol_pump_l.jpg
How do I change this text
The STS Alky kit is just a on/off set-up (unless they changed the system) I'd recommend AlkyControl, or like from a sponsor...
and
Another vote for both FMIC and ALKY...
and
