what gears are you running?
hey guys i just a 12 bolt with 3.42s
what do you have ?
what kind of times in the 1/4?
what size tire do you run ?
what size tire should i run for the track
i have a twin turbo APS M6 car,it makes 625rwhp and its 3620lbs with me in it
thanks alot
what do you have ?
thanks alot
LS1Tech Co-Founder
Formula, 3.50 gear, 325/28" tall tire
Camaro, 4.10 gear, 28" slick.
I think you will run 130mph or so, takes time to dial in a new combo and M6 is even harder. I'd consider running a 28" tall to hook it, or use a 2 step and run 26's. An 9-9-.5" 28 will fit with minimal work, but a true 28x10.5 slick will require a good amount of clearancing.
1. 1998 stock engine, t76, 2.73 gears, th400 275/40/17. Daily driver low 11's
2. 1999 stock short block, pt76, 3.00 geared 9" th400 11.5x26 et street= 10.20 @133
3. 1987 iroc, 3.25 geared 9 " 40 spline axles, 315/60/15 drag radial....th400 no times ...............yet.
m6....good luck.
m6....good luck.
