Low numbers on turbo
Old 05-26-2008, 01:32 PM
JerikSS's Avatar
Default Low numbers on turbo
I am only pushing around 450whp and 465rtq. It seems that with all the things in my sig it would be more, im also running 8ps1. Where do yo guys see I can improve my performance.
Old 05-26-2008, 01:58 PM
OUTLAWZ RACING's Avatar
Mustang dyno?
Old 05-26-2008, 02:05 PM
JerikSS's Avatar
Dont know too much about dynos, I got it tunned at haddad motorsports here in L.A They take the wheels off and the dyno attached at the wheel studs...
Old 05-26-2008, 03:40 PM
Sideways240sx's Avatar
dynapak dynos prolly...
i dont know how those dyno in comparision to dynojet/mustang.
If you got us graphs of your pulls we could be more help. Id say your getting close to being out of injector aswell. Also you probably need some stiffer vavle springs in those heads. Were the dyno's done with the cutout open?
Chris
Old 05-26-2008, 05:05 PM
veee8's Avatar
If it was a black SS it would make more horsepower !
Old 05-26-2008, 05:10 PM
cablebandit's Avatar
if its the svo 42# injectors, you got a long ways to go before being out of injector.
Old 05-26-2008, 06:11 PM
TransAmcoupe98's Avatar
yea the duty cycle probably is at around 65%.
Old 05-26-2008, 09:59 PM
Websy21's Avatar
I agree on the 42's, I will be using a single walbro and 42's on my stock block and plan to push b/w 500-550rwhp with no probs.
Old 05-27-2008, 12:35 AM
ninetres's Avatar
Why skimp on the fuel system? Seems rather important. I started with a single walbro and racetronix hotwire kit and ran out of pressure above 5000rpms. I was running 60lbers and 10psi on a T76. Making 650whp though (M6/10 bolt at the time).
Old 05-27-2008, 12:44 AM
Websy21's Avatar
I totally agree with you. I have a custom sumped SS tank, -10 feed, -8 return, aeromotive pump and boost reference regulator with 60lb injectors and aftermarket rails. The problem is that I am putting the turbo kit on my stock block, for now, and the 370 that is built with L92/l76 combo and the injectors/rails won't fit on my LS6(shorties, etc). So I didn't want to go all out and buy a bunch parts I won't be using for too long. Beside, I won't be pushing it hard since I too will be on the stock drivetrain. Shooting for no more than 500rwhp, about 5psi or so max. Otherwise, ya it would be pointless but I basically had the walbor and 42's borrowed to me until the 370 is transplanted.
Old 05-27-2008, 03:35 AM
Someone correct me if I'm wrong but if you go overkill on your injectors, dont you risk the possibility of running really fat at idle?
Old 05-27-2008, 11:59 AM
lt170chevelle's Avatar
just a matter of tuning
Old 05-27-2008, 12:19 PM
Firechikn's Avatar
Mine idles at 800 with 96's, all in the tune. If I wasn't going to push a lot of power, I'd run the motron 60's and be done with it. Those are easy to tune down, and can support a lot of power if you push them. I'm the over build it kind of guy.
Old 05-27-2008, 06:09 PM
JerikSS's Avatar
That is what the tunner said at the time. I was running out of injector, but with all those things I still think I am a little low in my numbers. I originally thought 500hp/500tq at the wheels easily but no cigar.
Old 05-27-2008, 07:00 PM
Black01M6SS's Avatar
^^^ Very true.
Old 05-27-2008, 07:17 PM
Hugger Z's Avatar
I have the racetronix and Motron 60lbers. Stock bottom end. Just upgraded to LS6 valvesprings and hardened pushrods. I see you changed the cam. Did you do the springs too? 7psi, 508rwhp. Not sure what to tell you. Your cam should be helping you too. Is your turbo choked out? You have emissions, right? I took all that off. I bet I would be lower if I put cats and the air pump back on.
Old 05-27-2008, 08:04 PM
JerikSS's Avatar
I have the racetronix and Motron and 42lbs. I have 918's valve springs. I took emission out already, no air pump or anything like that. Its a 2001 so I have the ls6 intake. Its weird, something has to be wrong but the car runs okay.
Old 05-27-2008, 08:31 PM
Schantin's Avatar
Really need more info, especially the dyno-graphs. A low AFR will hurt power and timing set too low will absoltely kill power as well. As example, my car's set to a pretty conservative 11.0 to 1 AFR and a not so conservative 20 degrees of timing. That was good for 453RWHP on 5PSI. The FIRST run of the day was 10.2 to 1 AFR and 16 degrees of timing (I had it way conservative before the dyno ) That run only netted 376RWHP! So, leaning out the AFR by .8 and adding 4 degrees of timing increased 73RWHP.
Your parts combo looks good. I'd look at the duty cycle of those 42lb injectors too. For my personal application, I was in the 90% range on my 42's and stepped up to 60's. Not sure why my car likes to chug gas...... but that's what I saw.
Good luck.
Old 05-27-2008, 08:46 PM
JerikSS's Avatar
I am going to change some of the piping around and see how it goes. I am going to tune it myself, and hopefully get this thing up a little.
Old 05-27-2008, 09:40 PM
what turbo comes on that kit.. If its a smaller turbo, or low ar that is probably the issue as mentioned.
Chris
Quick Reply: Low numbers on turbo
