Blowing oil out rear main
Old 05-26-2008, 08:29 PM
firehawk618's Avatar
Default Blowing oil out rear main
Help!!!
See sig for build.
After build forgot to modify pcv and after a few good boosts blew oil out rear main.
Replaced rear main, reconfigured pcv to both valve covers y-d together to a catchcan. Catchcan to inlet hat on blower.
Worked fine for weeks.
Hose came off inlet hat and I didn't notice it right away. Now have quite a leak out rear main again. UGH!!!!
What am I doing wrong? There is no oil residue out exhaust so i'm thinking there's nothing wrong with the pistons or rings.
Thanks.
Old 05-26-2008, 10:11 PM
427's Avatar
If you Y the lines together, you make them one line in the flow ability. Run each line seperate to the catch can and increase the line size if possible.
Kurt
Old 05-26-2008, 10:18 PM
Websy21's Avatar
Kurt
What he said!
Old 05-26-2008, 10:31 PM
But honestly how much flow do I need to the catchcan. Is there really going to be that much pressure and if there is then i'd think there's a problem. Am I mistaken?
Thanks.
Old 05-26-2008, 10:37 PM
SuperZ's Avatar
couldnt u just run breathers?
Old 05-26-2008, 10:39 PM
I thought there is supposed to be some vacuum in the crankcase to keep the fumes out? I'm confused on all this pcv crap tho. If a breather on each valve cover solved it that's what i'll do. Wont that puke oil on the motor tho?
THanks.
Old 05-26-2008, 10:51 PM
427's Avatar
Your breathers ability to flow air should increase as much as the HP. If you double the HP of the stock engine, you should double the breathers ability for a nice safe set-up.
Kurt
Old 05-26-2008, 10:52 PM
Kurt
That makes sense. So deleting the Y, running 2 catchcans, then where to go with those....
Old 05-26-2008, 11:17 PM
SuperZ's Avatar
so is a breather on each valve cover not going to work?
Old 05-27-2008, 06:19 AM
Jontall's Avatar
A breather on each valve cover works on mine with 12lbs of boost.
Old 05-27-2008, 06:43 AM
Reject's Avatar
i'm sure with aftermarket valve covers yes?
Old 05-27-2008, 08:50 AM
DanWS6's Avatar
I put breathers on each line coming form the rear of the valve covers and on the front passenger line I run to catch can and then into the intake. I got tired of oil spraying all under my car due to the sloppy design on the inlet hat. Granted that was before I added a catch can so it probably wouldn't be as bad now.
Old 05-28-2008, 01:55 PM
94m6Z28's Avatar
what about on stock motors at low boost. do they need a catch can?
breather?
leave it stock?. i just put a new rear main in and i dont want this to happen to me *no offince ment*
Old 05-28-2008, 06:03 PM
cablebandit's Avatar
dont forget the newly revised oil seal goes in "backwards" compared to the older/original one...it says it on a piece of paper in the seal packaging....just a thought
Old 05-28-2008, 08:13 PM
Thanks I did catch that. The new design even comes with a centering / installation tool. I did look at the seal closely and it is marked which side goes out.
Quick Reply: Blowing oil out rear main
