Who has installed a gm 3bar sensor on ls6intake?
Old 05-29-2008, 02:20 PM
SPRAYED 01's Avatar
Default Who has installed a gm 3bar sensor on ls6intake?
I just got my fast/gm 3bar map sensor from speed inc. Looks totally different than the stocker. Just wondering who has done this and what modifications are needed to run the sensor? Also any negative effects of running this 3bar tune.
Alex
Part # 12223861
Old 05-29-2008, 02:22 PM
LS1Tech Sponsor
hellbents10's Avatar
Most likely you got the rectangle shaped old style gm map sensor. You will just need to run a vacume line to it and get the appropriate connector.
Old 05-29-2008, 02:40 PM
SPRAYED 01's Avatar
Okay that was what i was thinking. I am getting the speed inc pigtail connector hopfully tomorrow. Is it okay just leave the factory one in there as a plug? Also any recomended spots to pull the best vacum/boost reading from the intake?
Alex
