Vacumn leak in cylinders 2 cylinders causing injectors to max out?
Old 05-29-2008, 04:57 PM
9t8z28's Avatar
Default Vacumn leak in cylinders 2 cylinders causing injectors to max out?
I just installed a Procharger on my LS1 and the shop is tuning it and they are telling me that I have a vacumn leak in two cylinders that is causing 2 injectors to max out. Does anyone know what would cause this?
Old 05-29-2008, 05:06 PM
TS6
TS6's Avatar
If thats what they literally said I would get my car away from those idiots ASAP.
Old 05-29-2008, 05:11 PM
9t8z28's Avatar
They are a sponsor here.
I don't understand how it could throw off only two cylinders. They tuned my car previously and there was no problems at all.
Old 05-29-2008, 05:41 PM
TS6
TS6's Avatar
Unless you have blown head gaskets, how do you get cylinder-specific vacuum leaks? And if you did blow the HG's, it wouldn't be a vacuum leak under boost.
Somethings not right....
Old 05-29-2008, 05:51 PM
9t8z28's Avatar
Could a vacumn port not be sealed and cause this?
Could an injector cause this? He said that he had all of the injectors set up correctly?
Old 05-29-2008, 05:53 PM
9t8z28's Avatar
I am lost and I don't know where to start?
He didn't give me enough info to at least lead me on where to start.
Old 05-29-2008, 08:21 PM
9t8z28's Avatar
****UPDATE****
I talked to the tuner again and he stated that I have 16" to 17" of vacumn and the car is running in "open loop". Now, this is causing the car to run lean at an A/F of 16.5:1
So now I know that I have a vacumn leak, but this is not a good enough reason for 2 of the 8 injectors to max out.
What is a good amount of vacumn to make the car run in "closed loop"?
Old 05-29-2008, 09:09 PM
OUTLAWZ RACING's Avatar
I run around 15 -17 of vacume at idle with a big cam on my turbo set up. Not sure why the injectors are maxing out or showing weird setting
Old 05-29-2008, 09:31 PM
calongo_SS's Avatar
16 to 17" of vacuum is not causing the car to stay in open loop, something else in OL/CL tables is.
Being in OL is not a reason for car to be that lean either. The car should be tuned in OL before it is put in CL anyway.
FWIW lots of people (including myself) run open loop all the time.
Old 05-30-2008, 07:19 AM
MIGHTYMOUSE's Avatar
my car idles at about 13" and 10-11" in gear (auto) though i am not sure why, runs fine
spray something over the engine pay and you will find or not find a vacuum leak.
as above a leak will leak pressure under boost, and not have anything at all really to do with the wot tune up.
Old 05-30-2008, 08:01 AM
9t8z28's Avatar
How do I tell the guy tuning the car that?
Old 05-30-2008, 08:04 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I have about 10" to 11" of vacuum at idle with the car is drive. This is mainly due to the big *** cam. A couple of things do not add up:
1) How do they know 2 of the cylinders have a vacuum leak? Have they done a leak down test on all the cylinders? So a cylinder to have low vacuum, the rings will have to be shot or the cylinders no longer square.
2) If the car has a A/F ratio of 16.5:1 in open loop, air is getting into the engine somewhere after the MAF sensor. Check for leaks at the MAF housing, throttle body, and intake manifold. If you have low vacuum at idle, a leak somewhere in the above sections will cause it and not the cylinders.
3) Either one of these problems will not cause certain injectors to max out. Something else is causing that.
If a shop can not figure these things out and you are forced to ask them here, I would get the car out of there ASAP.
Keith
Old 05-30-2008, 08:08 AM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
like MM said check for leaks using brake clean, spray around the intake where it meets the heads, rear part, and by the TB. the idle will change if there's a leak present.
Old 05-30-2008, 09:04 AM
TS6
TS6's Avatar
Either way it sounds like they don't know what they are doing. Have them chime in here, maybe they can explain it better.
Old 05-30-2008, 09:09 AM
9t8z28's Avatar
Keith
Thanks for the help. I will look into all of this.
Old 05-30-2008, 07:42 PM
9t8z28's Avatar
****LAST UPDATE****
I found the problem. The intake is leaking "only" on the right bank!
Last year I installed a LS6 intake, ground down the webbing where the LS1 coolant crossover pipes run under the intake. I never seemed to have a problem even after it was tuned for just the bolt ons. Now after the Procharger install, somehow it is leaking and I can not get it to seal, so I am gonna put on the new coolant pipes and take it to the tuner again. Hopefully I have solved the problem.
The carb cleaner didn't seem to work, but maybe it was just a bad spot for it to show.
Old 05-30-2008, 08:00 PM
veee8's Avatar
Most of the cheap carb or brake cleaner's have gone cfc free and non flamable. Check the can to see what it says. It is getting harder to find "good" brake clean.
Old 05-30-2008, 08:23 PM
9t8z28's Avatar
I was hoping to get 7-8# with the P1SC stock balancer and 3.75" pulley on my stock LS1 w/ LTH's, but I am getting 9#!! How does that happen?
I measured the diameter of the pulleys from where it contacts the belt. Am I measuring the pulley wrong?
Quick Reply: Vacumn leak in cylinders 2 cylinders causing injectors to max out?
