Lingenfelter 2-step installed - LS1TECH
Thread Tools Search this Thread
Old 05-29-2008, 11:53 PM   #1
Zombie's Avatar
Default Lingenfelter 2-step installed
Installed my lingenfelter 2-step tonight and did some testing. Unforutnately it doesn't help me spool any faster on the trans brake. It just limits the amount of boost it will make on the brake. Tried it at several different RPM settings and ended up leaving it at 4300 RPMs which kept my boost at 7psi so I can at least concentrate on tree. Don't know if it's worth the $250 for me though. Still takes about 5 seconds on the transbrake to get to my launch boost which is too long in my oppinion. I've experimented with my timing values and I have them where it spools the fastest (more timing). I think the real problem is the stall is too tight for this combo. Might have to try out a Chance converter.
Possible solutions include:
trying a smaller a/r on the turbo
higher stall (current one flashes to 2700)
Nitrous
Flame thrower kit (nothing says "back the **** up, i'm spooling" like a 10 foot flame out the tail pipe), idea from my friend who built my car.
Zombie is offline   Reply With Quote
Old 05-30-2008, 12:21 AM   #2
rojows7's Avatar
good info to know when i go auto...thx for all the great ideas zom...
rojows7 is offline   Reply With Quote
Old 05-30-2008, 12:33 AM   #3
trans2000am's Avatar
i like the flame thrower kit
trans2000am is offline   Reply With Quote
Old 05-30-2008, 12:52 AM   #4
MY99TAWS6's Avatar
If you have the newer ling two step it has antilag built in? Did you play with that part of it? I don't have mine installed yet . Auto should be able to leave at high boost. Guess you have some optimizing to do on your setup but mabye too much boost off the line is not a good thing necessarily depends on the traction situation.
MY99TAWS6 is offline   Reply With Quote
Old 05-30-2008, 01:56 AM   #5
RUNINHOT's Avatar
Do you have a vid of the 10 foot flames, I'd like to see that.
RUNINHOT is offline   Reply With Quote
Old 06-03-2008, 03:14 PM   #6
LS1Tech Sponsor
Jason Haines @ LPE's Avatar
Default Boost off the line
Did you try using the timing retard feature while on the transbrake? This should cause help increase your exhaust temperatures which will help drive the turbochargers. It will also reduce your engine efficiency so your mass flow will need to be higher for the same load so that should provide more gas flow to drive the turbocharger(s) as well.
Nitrous
Jason Haines @ LPE is offline   Reply With Quote
Old 06-03-2008, 06:46 PM   #7
BLNLS1/RX7's Avatar
Mine is working great with no problems.
BLNLS1/RX7 is offline   Reply With Quote
Old 06-03-2008, 06:53 PM   #8
98catfish's Avatar
sounds like your converter is way to tight. You could also try leaning out the fuel on the launch to help spool.
A good way to test your converter is to bring it up on the brake and check your rpms at 1# of boost, this will tell you your true stall.
Hope this helps.
Doug
98catfish is offline   Reply With Quote
Old 06-03-2008, 08:03 PM   #9
will a 2 step work with a 6 speed car, or is it more for auto's
thanks
ruquik is offline   Reply With Quote
Old 06-03-2008, 08:25 PM   #10
MY99TAWS6's Avatar
Two steps are normally required for manuals.Manuls have problems building boost off the line. For my dsms they have this option in software you get two step ,anitlag to spool up big turbos at the line and no lift to shift as manuals lose boost each time you shift.
Autos with stalls normally build good boost. You could still use the two step to get consistent launches and can't see why you can't use anitlag and as said pretty sure thats basically what lingenfelter has added on the new 2 step that I got. And thought you can upgrade the older version too.
Old 06-03-2008, 09:27 PM   #11
BoostnTBSS's Avatar
Quote:
On my setup i use my Step retard for the NOS controller which allows for timing to be retarded to zero and will add this LPE 2 step if i need more... its all in the tune!!! try wiring in a switch with the TB to have a diff fuel and timing curve by using coolant sensor its all in the tune!!!
BoostnTBSS is offline   Reply With Quote
Old 06-03-2008, 09:41 PM   #12
B18B1LS1's Avatar
I can see upping the timing with an auto and t-brake for spool if you don't run a 2-step, but WITH the 2-step have you tried pulling a bunch of timing out?
B18B1LS1 is offline   Reply With Quote
Old 06-03-2008, 09:58 PM   #13
perdieu's Avatar
Just hooked mine up friday night.. I can see 10 psi I have mine set at 2400 and foot brake it.. on the trans brake I set it at 3300 it blows the DR's off..
I'm running 23* or timing with a 370ci .76 up to 9psi then back to 20* for the uppper psi
perdieu is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Tips on getting spool time down? dville_gt Forced Induction 18 02-29-2012 05:57 PM
sluggish boost on transbrake Dracer91 Forced Induction 15 08-04-2010 02:46 PM
More trans brake, 2 step and timing testing on my ST80 Zombie Forced Induction 14 09-15-2008 08:38 PM
Question on spooling time taillights Forced Induction 18 01-25-2008 02:02 PM
how to build more boost on the launch with auto parish8 Forced Induction 22 05-03-2004 12:23 AM
Tags
2step, auto, boost, boosting, brake, flame, flames, install, installation, lincolnfelter, lingefelter, lingenfelter, ls, spool, step, trans, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
