finally got the rear mount done and dyno'd.
Old 06-01-2008, 11:34 PM
blacksi's Avatar
Default finally got the rear mount done and dyno'd.
I have used this site for sooo much of this build. Great info on here. So I'd thought I'd share teh results. I originally bought a 12# spring for the wastegate but it's opening at 10 but oh well it's good enough for now.
A local shop today had a dyno day on a dyno dynamics. I had my fuel pressure set too high (bolt came loose and I retightened it and notice after the pulls it was 5 psi too high) which made it run rich as hell 10.3 AFR. . Notice the curve with the dots is torque and relates to the numbers on the right HP on left. I was pretty happy.
675 and 820ish.
It looked like it was gonna break loose.
ls1 rx7 dyno - Video
Old 06-02-2008, 01:06 AM
TARZAN's Avatar
What are the details on the setup? Nice numbers!
-Will
Old 06-02-2008, 01:12 AM
LSWONGTO's Avatar
Awesome #s man I would also like to know what heads/cam/gaskets you have used.
Old 06-02-2008, 08:18 AM
blacksi's Avatar
forged 347 ci should be around 9.25CR .04 cometic gaskets Patriot stage 2.5 with 921 spings
tial 44
turbonetics t76 .96
All stuffed into this.
http://videos.streetfire.net/video/l...yno_164179.htm
Old 06-02-2008, 08:47 AM
Schantin's Avatar
Excellent #'s. Torque is awsome for 10lbs boost
