Will Procharger make enough CFM??
I am putting together a 408 with ETP 245 heads, custom cam not determined, and 1-7/8 headers. My question is will a Procharger P1SC push enough CFM to make boost above 12 PSi and be effecient. I usually do turbos but Ive got the blower and figure I might use it. Thanks for any input.
I agree, you're going to need an F-1A. With my 408 with AFR 225 heads, we're seeing 18 psi in the heat of the day with the impeller speed maxed out. We see 20 psi when it is cooler out at night. http://www.exoticperformanceplus.com...Car.php?car=12 Bob
