3.4 Whipple Build
Old 06-09-2008, 04:40 PM
Frans96SS's Avatar
Default 3.4 Whipple Build
Sorry to get you guys excited but its not on an LSX car. A good freind of mine blew his car up 11 days after he bought it. It had 20k miles on it with a 2.2 KB, Solid Axle ect.
well instead of just fixing the short block we decided to go alittle overboard..
We did Custom Ross Pistons, stock Rod with ARP 2000 Bolt, new set of ARH headers, 3.4 Whipple, new clutch and 26 spline input shaft, Complete new fuel system ect.
car made just under 600 before. We are hoping for alittle more this time around.
Old 06-09-2008, 04:45 PM
1972chevelle's Avatar
howd i know it was gonna be a cobra? haha good luck bud
Old 06-09-2008, 09:08 PM
venom ws7's Avatar
That blower is huge I love those year Cobras.
keep us posted with some numbers please.
Old 06-09-2008, 09:11 PM
daniel6718's Avatar
locally they took the rear plenum on the 3.4 and made it a bunch bigger for more volume...same tune same pullies picked up over 100hp...should do it!
Old 06-09-2008, 09:21 PM
MYSTIC-1SC's Avatar
should be a sic car, good luck on the build
Old 06-09-2008, 10:15 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Those 3.4 whipples are amazing.
Old 06-09-2008, 10:18 PM
krazy4's Avatar
Fatty blower!
Should make some pretty crazy numbers.
Old 06-09-2008, 10:51 PM
Z06PSI's Avatar
Forged 4.6L?
Good luck by the way. Post up when it is done.
Old 06-09-2008, 11:06 PM
Frans96SS's Avatar
already done...
Old 06-09-2008, 11:07 PM
Cmarsh's Avatar
Its a really good blower...we work with alot of those at the shop. I am actually the guy who builds the larger rear plenums.....but it looks like you have already done alittle work to the one you have I think you'll be really happy with it...800 rwhp should be no problem at all!
Chris
Old 06-10-2008, 12:21 AM
borninatransam's Avatar
3.4 whipple= the sickness. we have a local guy running a whipple 3.4 and hes making some damn impressive numbers compared to his old KB.
Old 06-10-2008, 07:48 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Those look like RC 75# injectors
Keith
Old 06-10-2008, 08:06 AM
gator's 99TA's Avatar
that blower combo makes me think about buying a cobra as a daily.
Old 06-10-2008, 09:54 AM
Z06PSI's Avatar
Or a C5 Corvette.
Old 06-10-2008, 10:50 AM
Hennytime's Avatar
ya theres a local guy with a 3.4L on his lightning, running 10's in the 1/4 mile and low 10's wit ha small 50 shot
Old 06-10-2008, 11:01 AM
Killer_Z's Avatar
damn, got my hopes up a bit.
Old 06-10-2008, 11:13 AM
Frans96SS's Avatar
Originally Posted by redrumss
Forged 4.6L?
Yes forged 4.6
Keith
You sir are correct
we are hopeing to go a tad faster... we will post numbers shortly.... Hoping to fire it up today.
Old 06-10-2008, 12:28 PM
pozesd99''s Avatar
we are in the process of a build with the 3.4 whipple too on our cobra
this is the mod list:
Engine, Induction, Exhaust, Electronic Components, and Fuel:
5.1L Cobra Stroker Motor
Oliver Billet Rods
Forged CP Pistons
Forged Stroker Crank
Stage 3 Ported 04 Cobra Heads
Stage 3 Custom Grinded Blower Cams
Adjustable Cam Gears
Stainless Steel Valves
Comp Cams Springs
9.0:1 Compression Ratio
3.4L Whipple Supercharger (28 psi)
PSR Cold Air Intake
SCT BA3000 MAF Sensor
SCT Chip with Custom tune
Accufab Single Blade Throttle Body
03-04 Cobra Intercooler (air to water)
Custom Racing Return Style Fuel System by Performance Solutions of AZ (includes fuel pump, fpr, rails, lines)
95 lb/hr injectors
Oil pump with billet gears
SFI Innovaters West Balancer
Kooks Custom Long Tube Headers
Dr. Gas X Pipe
Mac CatBack (3")
Drivetrain and Suspension Mods:
Lightened Flywheel
Spec 3+ Clutch
Terminator T-56 Transmission
Steel Drive Shaft
PSR 8.8" Solid Rear Axle (Heavy Duty for Drag)
3.73 gears
True Track
Caster Camber Plates
Custom Coil Over Kit
Mega Bite Senior Solid Mount Pair
Solid Rear Bushings Pair
Adjustable Upper Control Arms
PSR K Member and Arms
Subframe Connectors
Cooling Mods:
PSR Head Cooling Mod
LFP Supertank Intercooler Reservoir
Fluidyne Cobra Intercooler Heat Exchanger
sorry for the lengthy post hahahaha. we are expecting to put about 850-950rwhp through a built 6 speed... trying to go for the record for the fastest street 6 speed cobra ever
Old 06-10-2008, 12:36 PM
Hennytime's Avatar
Originally Posted by Frans96SS
Yes forged 4.6
You sir are correct
I think your fine. you won't be dragging a 4000lb brink
Old 06-10-2008, 01:08 PM
351carlo's Avatar
Thanks for the kind words guys. I knew I was in trouble when I bought a Ford, but I made that mistake for the first time at age 17.
The car is coming along nicely. We went with a return fuel system and yes they are 75lb injectors from RC Walbro GSS342 in tank pumps with a billet fuel hat and rails from Fore. I tried out the nylon braided line for the first time and WOW it is nice stuff.
The inlet was modified.... heavily. Hopefully it'll flow something decent enough to not be a restriction. It's a Gen II rotor profile 3.4 with the revised inlet so the throttle body is the restriction. We're running a 110 JLT MAF with a GT500 sensor and a MAFIA so that won't be the restrictive point, the single blade accufab will.
The motor is pretty built. We stuck with a stock crank and rods, since they're a 4140 Kellog and H-beam Manley from the factory. The pistons are Ross custom for high boost. ARP2000 studs throughout, and ARP2000 rod bolts as well.
For anyone contemplating this blower make sure you're running a STOCK lower pulley and a 26 spline input shaft on the trans. The aftermarket lowers are causing crank snouts to snap off behind the timing gears and your motor is gone. The stock lower has a crank support built in.
We'll get some numbers hopefully soon. I'd like to see 675 on pump and 800+ on race gas and high boost.
Quick Reply: 3.4 Whipple Build
