turbo 6.0
turbo 6.0
im doing a forged bottom end lq4 in my 98 z28 with a t76, 233/239 114 ,and a 4l60e does anybody have any suggestion on the the best set of heads i should use? i will be methenol injected and i plan on boosting about 14 pounds.
I did stock 317's on my last 8.5:1 370ci. Made over 770rwhp at 15lbs of boost with a TC76.
The new shop car is getting a 9.8:1 370 with stock 317's. Shooting for over 775rwhp. Bigger turbo this time around.
Ona budget, use some 317's as stated and then buy a good rear end. The 4l60e if it is upgraded should hold you at the 700rwhp mark. That seem to be about the limit. You shouldn't break hard parts in the tranny,it's just that the clutches will not hold, from my experience with them. If you want to keep the overdrive, then you can buy a basicly stock 4L80e and you will be fine.
