The Poor Mans ls1
Old 06-12-2008, 08:34 PM
Misflt's Avatar
Default The Poor Mans ls1
I thought you guys would get a kick out of my build. Turbo/meth 3.4l. Should be running in a week or 2. Looking to match stock ls1 numbers as far as HP goes. Goal is to beat my uncles 07 Mustang GT. More pics to come...
Old 06-12-2008, 08:37 PM
sciff5's Avatar
All that time and energy.. why not get a 5.3 you can get them dirt cheap?
Old 06-12-2008, 08:41 PM
presto_z's Avatar
i like when people do things like this.. its definitely out of the ordinary, there are a few turbo 3.8s on here but no 3.4s to my knowledge
post up some more pics if you could
Old 06-12-2008, 09:07 PM
Coy
Coy's Avatar
Awesome. Post up some more pics when you get it further along.
Old 06-12-2008, 11:44 PM
SStolen's Avatar
My prediction: Its gonna Then you're gonna
But best of luck to ya. I love seeing this kind of stuff too. What kind of tuning software is available for the 3.4's anyway? How do you plan on tuning it?
Old 06-13-2008, 12:38 AM
Misflt's Avatar
IMHO its waaaay less time and energy spent to go the turbo route, especailly since I have limited tools/help. There is no real tuning available for the car, unless you build a stand alone. Im ganna use a cartech FMU and #24 injectors to get a rough tune. I might look more into megasquirt if I cant get it to run right.
Old 06-13-2008, 12:55 AM
barnat's Avatar
I like the cartoons my man LOL NEVER, EVER, saw these ones yet!!!Im with the other guys on this one!!! For what you got into that turbo and the $160 battery, you could have bought a LS1 ****, I got a set of 02 Camaro manifolds I would have given you and still would if you change your mind ****!!!half the guys reading this would probably donate parts as well if you just wanted to stop this crazzzzy ness and just put a LS1 in THEN!!!!put that DAMN TURBO on and now well be talkin here my man!!!
Old 06-13-2008, 07:05 AM
veee8's Avatar
There is quite a bit more to the swap than just throwing a V8 in there! It nickel and dimes you! Oil pan and pickup, balancer, alternator, water pump, power steering, K member, transmission?, Power steering rack, ECM, wire harness, intake, it goes on and on. Much more than people are going to want to "donate". I like the turbo plan. The 3.4 isn't the most durable, but it should be interesting!
Old 06-13-2008, 07:32 AM
Red97Z's Avatar
Throw a 75 shot on top of it
Old 06-13-2008, 12:02 PM
great421's Avatar
Default 2X Vote!
I second that!
Old 06-13-2008, 06:33 PM
CHRIZ28's Avatar
I think it's a pretty cool idea too. Keep us updated!
Chris
Old 06-15-2008, 03:27 PM
MonochromeSS's Avatar
I am a big fan of putting an ls1 in anything. If its not fast enough, ls1 always helps.
But the v6 turbo, very nice, its unique. I like it.
Old 06-15-2008, 05:30 PM
BadgeZ28's Avatar
I like it. Pretty easy to make a V8 car fast. But you will really have a great sleeper when you are done.
kidcamaro98's Avatar
I had a 400hp + Turbo 3.8...they deff. suprise people! Pic's are in my fquick if you want to see how it was setup etc. It was a turbonetics T72
www.fquick.com/kidcamaro98
Old 06-15-2008, 05:49 PM
SS2win's Avatar
turbos are the best replacement for displacement. good luck with the build. definitely work out a tune of some sort if you want it to last!
Old 06-15-2008, 10:22 PM
NemeSS's Avatar
the tb on a 3.4 is small,
i helpd a friend build a turbo system for a 95 m5 3.4, camaro
the trans is a t5 with a 1 1/8 26 spline input shaft, the trans was pretty strong, but the motor did not like psi,
he used a begi mrfpr, it replaced the stock fpr and also acted as the adj. fmu
the turbo was a t60, using 30 lb. inj., it ran pig rich, but i would have to say it spooled the turbo pretty good, and saw 10+psi, felt like a bolt on's ls1
but the engine went on a hard run, it blew a gasket and locked the engine, but it run hard
Old 06-15-2008, 10:50 PM
Tiago's Avatar
looks familiar...
here is my other car before I swapped a Ls1 into it
View Video on FQuick
Old 06-16-2008, 08:54 AM
engineermike's Avatar
I STRONGLY urge you to consider the AEM F/IC. I have one on my PWC and it would be perfect for you.
Mike
Old 06-16-2008, 11:09 AM
Misflt's Avatar
Mike
Thats only obd2 where as I think I have OBD1.5 with a OBD1 port. Stupid 3.4 computer
And I have to give it up to TIAGO. He paved the way and was the first to prove all the 3.4 nay sayers wrong.
Old 06-16-2008, 11:38 AM
Reject's Avatar
nice!!
Quick Reply: The Poor Mans ls1
