how runs 10psi with stock LS6?
Hello guys,
I have cts-v which has LS6. My current set up is maggie, cam, headers and cat back. in past my car put down 489rwhp with 7pounds of boost and wanted to know if i can run 10psi with stock LS6 long block except camshaft. i have checked around and found mixed stories and wanted to hear from people actually run 10psi or more with there stock ls6.
thanks
thanks
yea it seems 500 ish seems to be the limit.. You have the ls6 valve springs which should help with the float issue if any. Id be more concerened of getting bad gas, and detonation.
get a wideband in the car, and keep your eye on it. I think it could be done for a while, but im not sure how safely.
Chris
Chris
I was running 9.5 #s on a stock ls1 w/ 10.5:1 compression. car made 480/480 w/stock manifolds and cats. I just put on the ARHeaders (1-7/8) and lost 1.5 #s. I plan on re-pulleying it back to 9.5 #s. I am also going to spray 75-100 on top of that.
My car was tuned by vengeance and has great driveability and no detonation also I am not running meth yet.
Doug
Not true, maggies like compression if your worried about the compresssion then an alchy kit is you best bet. 317s will drop your compression to about 9.5:1. 10.5 is better for the maggie.
Doug
Doug
I ran nine for the past 4 years with no problems its all in the tune. ECS has cars running 12psi and meth for the past few years. The cars are still going and run 9's with stock bottoms
do you have their phone number or website?
Thanks
i also thought the main problem is tuning as well.
