Fitting a 106mm turbo...
Race your car!
It will probably fit, but you're gonna have to move it over a good bit, and the downpipe and charge pipe will have to get redone, probably the feed pipe from the headers too.
I've seen Alfred's car and his is higher and over towards where the battery usually is alot more, and is facing the other direction from where yours is, and the feed pipe for the intercooler runs down where your downpipe is going.
Speaking of that, where does that downpipe go, back under the framerail out above the k member, or out the side in the front?
Race your car!
another quesiton, weren't you having issues with the low compression of the 346 being too low to spool the 88 quick enough?
A 106 is gonna be alot harder to spool then the 88 was. Ask Alfred how that was for him, last time I talked to him about it he said it's making alot more upper rpm power but it seemed like he lost alot under 5000 rpm, the power curve is more like a supra now.
LS1Tech Co-Founder
4" DP feeds a 4" Splitflow muffler that is hanging under the passenger side seat area, where that hump is.
Based on research I'd need to increase my engine cubes to 390-410ci to get the car to spool correctly. I have an LSX block in hand but I'm just kicking around some stuff right now. I know I'd have to modify my current hot and cold side setups.
LS1Tech Co-Founder
Not to worry about chassis cert, I can have my chassis guy do a 25.5 on the car anytime.
Mike @ Precision is emailing me the dimensions of the turbos so I can see how much needs to be moved.
Race your car!
John why not just change the heads on the car and get the compression up before bailing on the 88mm? You know that there's a ton left on the table with that turbo and the kit itself if you had the motor up at 9 to 9.5 to 1 compression.
That would be the cheapest route and probably the easiest. That alone would probably get you to the limit of the chassis cert.
Then have the car upgraded for a 25.5 and build the motor while the car's apart, then do the kit. It's probably a 4+ month project to do all of it anyway, if the car's gonna be down do it all at once, but in the meantime I would want to try to push what ya have first, unless it's hurt and you need to rebuild anyway.
LS1Tech Co-Founder
I'm not bailing on the 88mm, but to run the car competitively in drag radial classes I need to figure out what needs to be changed.
Putting the turbo in the nose is very popular, it would require redoing my turbo kit and radiator setup.
I'm pretty sure I can put the turbo over more to where the battery was and make it all work.
If you are redoing the piping, would you be better off to spin the turbo 180 deg. so the compresser side is where the battery used to be? Seems like that would give you more room and you can turn a 90 on your downpipe and run it down and back under the car wherever you want it to go. Was it Kyle's TA that was like that I think?
It is hard to look at a picture and pick a placemet though. Much easier to just unbolt what you have and set the 106 in there and see how/where it fits.
for gauging purposes, this is an S88 with a blanket.... hot side doesn't have much play room, but no issues:
for a 106mm, IF it would fit up there, you would need it further over like NastyTA's... or down low. if you split the frame rail, you will need to notch it.
My setup wouldn't really work for you w/o alot more fab work and losing the stock hood latch. You can't see it in the picture, but I do have a full size radiator sitting in front of the bar I built since the car sees a few street miles.
