will a MPT-70 .96a/r t4 fit the stock t4 sts kit
Old 07-01-2008, 05:24 PM
wstiles01z's Avatar
Default will a MPT-70 .96a/r t4 fit the stock t4 sts kit
I have a sts kit on my car now but I don't have a turbo. Thinking of going with a MPT-70 t-4 .96a/r. I just want to know if the turbo will fit or will have to modify the t-4 flange on my kit. ( maybe a stupid question)
All other imput would be appreciated I E...turbo choice for my setup (size a/r ?).
I have a 2001 Camaro ls1, SLP LT, no cats, MTI C1 hammer cam
222/222-.566/.566 lsa112,Crane dual valve springs,chromoly push rods, 2200 stall,bolt-ons, sts kit with sts meth,Wal-bro 255 pump and 42lb inj, 3.73grs, and stock A4 car has 45,000miles
also after turbo purchase/before tune I would like to change to E85 GOOD OR BAD???
Thanks guys
Old 07-01-2008, 05:35 PM
Monello's Avatar
I am pretty sure that a T4 is a T4.
Only difference may be the downpipe side, and compressor outlet.
Old 07-01-2008, 05:47 PM
wstiles01z's Avatar
Default thanks for posting
I believe I am looking at the same turbo you bought. I have been speaking with the guy from ModularTurbo about the T-70.
Old 07-02-2008, 02:08 AM
Johnv's Avatar
should be the same, but I think you will want a smaller exhaust houseing in a rearmount.
Old 07-02-2008, 03:11 AM
Oh4GTO's Avatar
The MPT-70 is an on center 3" v-band. I also agree with the smaller exhaust housing.
Old 07-02-2008, 03:55 PM
ModularTurbo's Avatar
I called STS, they said that they don't see why it wouldn't fit, no promises from them though.
Old 07-02-2008, 05:23 PM
kbracing96's Avatar
You shouldn't have a problem since it's an f-body kit and the WG isn't plumed back into the tail pipe. FYI MP exhaust housing are about 3/16 of an inch shorter in where the v-band is in relationship to the mounting flange then Garrett housings. I also would go with the .68 A/R housing in a rear mount like yours.
Old 07-03-2008, 07:40 PM
OUTLAWZ RACING's Avatar
.68 is way too small it is going to choke up top. .80 -.96 have been ran with good spool.
Old 07-03-2008, 08:03 PM
I said the same thing. He's an auto car too so he ain't gonna let off the gas.
Old 07-03-2008, 08:56 PM
bud8fan's Avatar
get er done!!!
Old 07-06-2008, 11:01 PM
redrocketSS's Avatar
I would sell your LTs and pick up a set of stock manifolds and then wrap the exhaust. It will make a world of difference
Quick Reply: will a MPT-70 .96a/r t4 fit the stock t4 sts kit
