Compression Ratio?
Old 07-01-2008, 07:37 PM
fkn_fst_lsx's Avatar
Default Compression Ratio?
Im currently working on a LS2 402 project.. Going with the procharger D-1 kit.. and about a 150 shot of spray.. anyone have any ideas of piston/head set up's? i was thinking -10cc pistons and a set of 66cc heads? sound good? not enough? to much?
Old 07-01-2008, 07:55 PM
OUTLAWZ RACING's Avatar
Why the no2? Somthin like that 8.8,1 or 9.1.1
Old 07-01-2008, 08:41 PM
MLP00Z28's Avatar
Whats up pal. If you run this setup you should get aprox 8.73:1 CR
Bore diameter: 4"
Stroke: 4"
Combustion Chamber: 66cc
Head Gasket Thickness: .05"
Head Gasket Bore: 4.03"
Piston to deck clearance: 0
Dish: 30cc
Hope it helps
Old 07-02-2008, 12:16 AM
Bore diameter: 4"
Stroke: 4"
Dish: 30cc
Hope it helps
And u base this off of what?
Old 07-02-2008, 08:01 AM
Dumb Ass Vette Moderator
ls1290's Avatar
8.7:1 is too low IMO for a S/C setup. I would run something in the range of 9.2:1 to 9.4:1. -22cc pistons with 66cc heads and 0.054" gaskets will get you to 9.3:1.
Keith
