Procharger Fan Setup
So I recently purchased a P1SC-1 Procharger kit, but it did not come with the fan or fan assembly. Should I purchase the original setup from Procharger or should I be looking at something better for cooling? Also if anyone has this for sale let me know.
I drive this car pretty much as a cruiser on nice days. But it will see a lot of summer days and possibly extended driving if I go out on road trips (~4hr drives).
That's the $364 dollar question. I haven't been able to find much info on this either. Now I know a guy here with a procharged Camaro that he said was having cooling issues with the AC on, but he put an additive called Hyperlube in and says it took care of it for him. However, I don't know how many long trips he takes in the car.
I have heard that SDCE and EPP add a smaller fan on the driver side of the shroud that seems to help. I may look at doing that, just getting the procharger shroud and adding a fan if I have problems cooling.
You'd think though for the price they want for a shroud and fan they could get it right (ATI not EPP or other sponsers) without the need to modify it.
Take a look at what we did on this T/A with an additional Spal fan.
http://www.exoticperformanceplus.com/hotCars.php?car=62
This is the fan we used.
http://www.exoticperformanceplus.com....html?item=729 Bob
I have read on epp website how they tend to add a smaller fan to the Prochargers original setup. But I really didn't want to have to go that route, unless I have to. Seems to be a bit pricey also.
I was also told that for hotter climates that I should go with a Pusher fan. Now I know a fans rotation will just depend on how its wired, however I am unaware of what type of after market fans are out there for an F-body that will also support a Procharger.
00PewterSS - I've had my car setup appearance wise like this since 2004. Granted I like it, I have a few minor changes in store
A puller fan is generally more effective than a pusher fan. You could stay with the oem fan assembly, and move the bottom radiator bracket forward an inch or so. This will allow the factory fan assembly to clear the ProCharger head unit. Bob
