View Poll Results: Auto or Manual? What are you running and why?
Auto-Street
40
36.36%
Auto-Track
15
13.64%
Manual-Street
51
46.36%
Manual-Track
4
3.64%
Voters: 110. You may not vote on this poll
Auto turbocharged vs. Manual turbocharged
Old 07-14-2008, 09:41 PM
Bird-Of-Prey's Avatar
Default Auto turbocharged vs. Manual turbocharged
Just curious, out of all the FI members here, who is running a manual trans and who is running an auto? I'm going to make this a poll to find out how many of each. I would also like to hear why you think one is better over the other and what your car is primarily set up for. IE: Auto is better for the 1/4 mile because ??? and manual is better for street because ??? Thoughts and opinions?'
Maybe even talk about what converter or clutch you chose for your set up and why. Also post how it's working for you and any recommendations you might have.
Old 07-14-2008, 09:59 PM
SPRAYED 01's Avatar
I think an auto with turbo makes the most sense. It will spool alot faster and stay spooled inbetween shifts. For a manual i think a sc makes more sense. Since it rpm dependent lag would not be a big issue.
Old 07-14-2008, 10:00 PM
otherwhitemeat's Avatar
There is a million posts on this.....do a search....FyI auto is better for both cause of the way it loads the turbo and the ease of launching with it........but last week I was doing some from rolls against some turbo-nitrous busa's and I got the power shifting down mint "with the help of a few secret tricks" and walk by them in forth gear.....but the best part was is the turbo never really fell off and the nose never came down. So it's doable to go low nines and well into the eights with a stick, it's just more work and a little scarier, I need a SFI bellhousing, but the launching is some thing I still need to work on....
Old 07-14-2008, 10:16 PM
I apprieciate your input, but the last thing you need to say to me is do a search. I've been on this board for years and don't remember ever seeing a thread like this. Let me clarify: I'm not asking which is better, like all other posts. (What's the best turbo, what will will give me the most power etc.) I am simply asking: Who runs what and why? As an addition, I'm asking what their car is set up for.
Old 07-14-2008, 10:22 PM
BTW I did do a search and found only two threads:
1- Auto or Manual March 07 (not very informative)
2- Auto vs Manual 2004 (joke)
Old 07-14-2008, 11:20 PM
landonew's Avatar
Very interesting thread.
Here is what i have read (am in the process of planning my next stage of upgrades and have considered going FI).
Track-car is an auto for obvious reasons. They are more consistent, and allow you to use a trans break.
Street cars will be dependant on your rwhp goals and the size of your turbo/turbos. For a relatively mild FI setup (talking 500-650rwhp), a manual transmission is fine. The size turbo for that application will spool fast enough to were lag between shifts shouldn't hurt you too bad. When you start getting into bigger rwhp catagories (650-1000+rwhp) th400 (or maybe a 4l80) is the way to go. There is the exception of a twin turbo setup where the lag is not to bad, but it better be right or you will be waiting for boost (experiencing lag) between each shift, thus not maximizing your application.
This comes down to the honest question you have to ask yourself. Do you want
1) a street car that you take to the track for fun (not trying to get deep into the 9s)
or
2) a track car that sees occassional street duty but that is gunning for mid-low 9s (or even 8s).
Anyways, probably enough talk from the NA/N2O guy huh?
Old 07-14-2008, 11:33 PM
sworaz's Avatar
Building boost through a stall converter rocks!
Old 07-14-2008, 11:36 PM
(landonew) - Thanks for your input. Again I don't need schooling on this subject. Just looking for who runs what and why. Thought it might be informative for others.
Old 07-14-2008, 11:39 PM
TurboOrange's Avatar
Turbo car should almost always be an auto car.. as said, it works and works damn well on many counts.
Old 07-15-2008, 02:56 AM
chvyboyls1's Avatar
My gto was an m6. With the maggie it never hurt me but when I went to a plate kit with a 125 shot It cooked a centerforce d-f and then the spec-3 would get warm and slipp if I ripped 2nd or 3rd and hooked. I'm leanin towards an auto on my next toy. I'm torn between n2o,procharger or turbo.
Old 07-15-2008, 04:37 AM
98transguy's Avatar
4l80e behind ofi85 kit.best of both worlds , consistent of a automatic with overdrive for highway driving.precision industries vigilante converter
Old 07-15-2008, 06:32 AM
stevieturbo's Avatar
Its entirely down to personal choice.
Performance cars in Europe all tend to be manual, old people's cars tend to be automatic
The US is obviously different, with the majority being automatic
For straight lines, there is no doubt auto will be faster....just depends what sort of driving experience you want from the car.
Old 07-15-2008, 08:50 AM
Murdock's Avatar
This has been beaten to death. Maybe your search was too narrow. Searching "titles only" for "auto" in this forum gives more than 2 threads. Check these out, there's a lot of opinion and bickering, but some good info too:
https://ls1tech.com/forums/showthrea...highlight=auto
Old 07-15-2008, 10:10 AM
ninetres's Avatar
Your poll choices suck. I have an auto.....but fopr both street and strip. TH400, 3000 stall, 3.25 gear.
Old 07-15-2008, 10:44 AM
H21surfer's Avatar
I run an auto and never go to the track. No doubt do I think it will be more fun to drive a M6, but it is nice feature to have an auto.
Old 07-15-2008, 11:09 AM
smokinHawk's Avatar
what is rpm s highway cruising at 70mph?
im debating between a 3.00 and a 3.25 gear with my th400
Old 07-15-2008, 11:28 AM
At 70mph, I'm at 1700rpm.....which isnt bad, M6
Old 07-15-2008, 11:29 AM
ninetres's Avatar
Not exactly sure. Haven't driven my car consistently for a while
My speedo also doesn't work since my cross bar under the dash pushes on the console a bit
I also run a zr1 wheel in back for street duty so the revs aren't super low. With the 28" slick its a little better. 70 is pretty fast. I bet I usually cruise around 60 on the highway.
Old 07-15-2008, 12:16 PM
Zombie's Avatar
Once you go Th400 with a turbo car... well, you make fun of all the M6 guys who don't know how good it is.
At 70 MPH I cruise at 2600 rpms in 3rd with a 25.5" tire and 2.75 gears. It's and odd setup compared to most, but it works pretty good for street/strip use.
Old 07-15-2008, 12:30 PM
Boosted 99 TA's Avatar
My car is a M6 and thats what i wanted, i just think its more fun to drive, i make decent power, i know an auto would make more sense. Im not lookin to be the fastest guy around town, i have fun driving my car, its still fast and thats what matters to me.
Quick Reply: Auto turbocharged vs. Manual turbocharged
