Advice on Engine...
Old 07-18-2008, 10:06 PM
ELMiN8oR's Avatar
Default Advice on Engine...
Ok here is the deal.
i'm getting a new procharger so i'm new to forced induction
Any way i've been making my own research on a good motor so after searching and reading, I've decided either to go with 347 Ci or a 370 ci. my aim is to reach 680+ rwhp with a D1.
so I need advices about which one should I decide also with a good budget
also i'm currently running a VRX3 cam: 226/228 .585/.588 113+3 LSA
should I keep this cam or change it to a bigger one ?
last quesion if I wanna go over 680 rwhp what heads should be getting?
Thanks in advance
Old 07-19-2008, 11:14 AM
venom ws7's Avatar
370ci AFR 225 with EPP Blower cam.
D1SC (if it was me i'd go with F1A) from EPP with FMIC with fule system.
the car should get 680rwhp+ with 14psi on pump gas maybe add METH kit since Kuwait is freakin Hot like Jeddah..
Good luck man.
Old 07-19-2008, 11:37 AM
Jake@EPP's Avatar
A 347 will not have the torque a larger inch motor will, if you are re doing your motor in the car currently check out doing a 382. More inches the better for part throttle torque and drivability.
Depending on the inches and the heads, our cam may work great with it. Its on the large side for a daily driver, but some people like it.
Ive seen results similar to the cam you have, it works pretty well. For a smallish daily cam a 226/230 113 would work great with a blower. I would honestly not change it up, since you already have it.
Depending on the inches you go with, a set of heads can range from $1300 to $3000. For budget head, check out the PRC 2.5 head. For a higher end head, check out the AFR 205 (depending on inches), or the trickflow heads. Both a solid winner.
Either way, a better head will really shine when your going max power.
And dont forget a 3.70 blower pulley
Old 07-19-2008, 06:06 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
As far as advice goes I say go with EPP. I wish I would have known this back in the day.
And guess what? They even answer phones and answer emails...
Old 07-20-2008, 07:15 AM
EPP
EPP's Avatar
We try! Thanks! Bob
Old 07-20-2008, 07:16 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...php?service=83
Check out our engine build in the link above. Bob
