AMS-1000 Boost Controler
How easy is this to use/setup? Does it do the same as the E-boost 2? Or can you time delay/ramp for each gear as well?
Ron
Thats what I want to know. I was leanning towards the E-boost 2 myself, until I was informed about this product. My car will see mostly street duty w/ DR's. I still think traction might be a problem
Ron
Ron
the ams-1000 has a decrease boost feature/ As soon as you trigger this input it will instantly subtract the target pressure amount you have programmed under this from the the target pressure you are currently at. As soon as the input is removed it will go right back to where it was.
the ams500 is a stripped down ams-1000. It offers 2 stages , one of them has a ramp that can be applied. The ams-1000 offers 6 stages and is much more flexible . I have a ams500 on my street car.
Either would work well for the street. The ams500 was designed as a street strip controller.
With the 500 or the 1000, is it possible to have boost based on speed? I have an M6 so I cant do it gear based without overcomplicating it.
