Smokinhawk Bracket,i Cant Find A Belt!!!
Old 07-21-2008, 03:45 PM
SPRAYED 01's Avatar
Default Smokinhawk Bracket,i Cant Find A Belt!!!
Okay im loosing my mind here. A 715k6 is to short and wont fit on,a 720k6 fits but is to loose and makes noise. Im running a 25%underdrive slp pulley and the speed inc manual tensioner.
What do i do?
Alex
Old 07-21-2008, 05:09 PM
Sideways240sx's Avatar
I have the march underdrive pulley. And a Thunder Racing tensioner. I run a 710k6 and its perfect. Its tight slipping on, i slip it over water pump last, then i put tension on and its good to go. Do you have the little bar installed right? Look at the pic below. Not mine but what smokin hawk sent me. Id imagine we would run the same belt as im all stock pulley's except the march underdrive pulley.
Chris
Old 07-21-2008, 05:21 PM
daniel6718's Avatar
no way a half inch is that much of a differance...
Old 07-21-2008, 05:29 PM
Monello's Avatar
Slip it on the Waterpump last. Only way I was able to get mine to work.
Old 07-21-2008, 05:44 PM
Well your saying you cant get a 715 on, and i run a 710. I have had it on and off 4-5 times. Its not to bad.
Chris
Old 07-21-2008, 08:00 PM
SPRAYED 01's Avatar
Okay i worked at it for a while with the 715. I use alittle silicon spray on the water pump and was able to get it on. The tensioner is pretty much not doing anything any more but it seems to be at the perfect tension. It goes on the dyno tomorrow so we will see.
Thanks guys.
Old 07-22-2008, 07:34 AM
smokinHawk's Avatar
sorry didnt get to check it to now, but yes the easiest way to get it on is to put it on the waterpump last,
glad to see you got it working.
the belts also might vary a little set up to set up, as each bracket arn't identical to each other but vary close.
