Victor Jr. W/Intake Elbow.com Elbow Problems
Old 07-22-2008, 09:11 PM
NASTY98TA's Avatar
Default Victor Jr. W/Intake Elbow.com Elbow Problems
Ok I Decided to go with a Intake Elbows.com Elbow, and I went to go fit it, but it hits my Stock Firehawk hood. Has anyone else had this problem?
If anyone has pictures of their set up i would appreciate it
Brian
Old 07-22-2008, 09:14 PM
bumpin_records's Avatar
yuo will have to cut the center section out of your hood, i have the firehawk hood I will take pictures in the morning.
Old 07-23-2008, 02:06 PM
LS1SpeedAddict's Avatar
You dont have to cut the hood with the edelbrock elbow
Old 07-23-2008, 02:50 PM
nope he is right with the edelbrock low profile elbow you will not have to cut your hood
Old 07-23-2008, 10:27 PM
NASTY98TA's Avatar
Default Edelbrock Elbow
Yeah but is it any better than my Nitrous Daves
Old 07-24-2008, 10:55 AM
DeltaT's Avatar
It won't flow as much because of the tight bend, but it will fit under your hood. Which is more important?
Jim
Old 07-24-2008, 01:39 PM
NASTY98TA's Avatar
Default Cutting
If anyone has pictures of the cutting they had to do on their stock hood I would like to see them
Thanks
Brian
Old 07-24-2008, 01:46 PM
Ryans_pewter_ss's Avatar
If u decide to not use that elbow pm me, i might be interested in it, i have the 3" ss hood so it should fit mine with no problem. Thanks and I hope u get it figured out.
Old 07-24-2008, 02:53 PM
TINKRD's Avatar
or you could take the elbow to a machine shop and mill off X amount off of the flange....
Old 07-24-2008, 04:14 PM
WeberRacingEquipment's Avatar
We have found that it also helps to mill the intake down some as well.
Old 07-24-2008, 11:07 PM
SSilverSSurfer's Avatar
tiago had to do the same thing, im pretty sure, if you search his name you cam see under his hood
Old 07-24-2008, 11:34 PM
JMBLOWNWS6's Avatar
Mill the intake and your good. I did not cut my hood!
Old 07-24-2008, 11:40 PM
NASTY98TA's Avatar
Default Mill the Intake
Sweet, now I just need to find someone to mill the intake...
Quick Reply: Victor Jr. W/Intake Elbow.com Elbow Problems
