Garrett TP38
Old 07-25-2008, 04:57 PM
Striker289's Avatar
Question Garrett TP38
I've got a lead on a Garrett TP38 that is local for $150. Its off a 99-03 7.3l Powerstroke with low miles. Its Specs Should be, .84A/R exhaust turbine housing And compressor side 1.0 A/R. What i would like to know is If that would work good on a Stock LS1 Long block. I'm planning on Starting fab on Front Mount turbo system late this fall and im trying to get a turbo before then. I only plan on 6 PSI on this motor.
Old 07-25-2008, 05:42 PM
engineermike's Avatar
Wheel sizes are much more important than AR's.
Old 07-25-2008, 11:01 PM
Striker289's Avatar
Not 100% sure but i've seen one or two people say its a 80mm compressor wheel.
Old 07-26-2008, 12:40 AM
Sabre_Logos's Avatar
The compressor wheel should be 59mm for the inducer. The exducer is 82mm but that doesn't matter when you are looking at a compressor map.
Old 07-26-2008, 10:53 AM
Striker289's Avatar
Heres a flow map for one of the tp38's http://www.thenebula.com/carpics/pics3/TP38ZOOM.JPG
How am i supose to read it?
Old 07-26-2008, 05:49 PM
LS1TECH Sponsor
DrTurbo's Avatar
Its essentially just a 60mm turbo. Its sucks for a LS1 motor....will spool fast, but fall off like a rock in the upper RPM's.
Old 07-26-2008, 05:53 PM
veee8's Avatar
Yeah it will do 30 psi on the diesel, but all done at 4500 rpm. Not too hot for a LS1.
Old 07-26-2008, 05:56 PM
LS1TECH Sponsor
DrTurbo's Avatar
Bingo......never was meant to work well on a high flowing LS1 motor. A little worse then even a 60-1 which is pretty much crap at anything over 5000rpms. Minimum, I would suggest a high flowing 70mm with a proper sized exhaust turbine wheel, around ~80+mm or more. The turbine is the most overlooked part of the turbo world...
Old 07-26-2008, 11:26 PM
Striker289's Avatar
Alright. Any Turbos Out there perferably of say a stock car or truck that would work good? I'm trying to keep prices down when i can. I know you can't go cheap on a turbo build though.
Old 07-26-2008, 11:45 PM
Sideways240sx's Avatar
If there was everyone would be buying them...
I would say the tc76 from dr turbo is going to be your best bang for your buck with a warranty and will work great.
Chris
Quick Reply: Garrett TP38
