Stock shortblock + 11psi + novice tuner...results inside
Old 07-28-2008, 12:41 AM
Black01M6SS's Avatar
Default Stock shortblock + 11psi + novice tuner...results inside
Nothing you guys haven't seen before but I figured I would post my results.
The pics are of the dreaded #7 piston. All of the other pistons looked great.
I was surprised to see that the top of the piston wasn't damaged. I've seen pic's of other pistons that supposedly had been in engines with detonation problems and it looked like someone had a go at them with a chisel and a hammer. Was it detonation that caused the ring land failure? If so why was the top of the piston not damaged?
The rings were holding all the pieces together. There doesn't seem to be any damage done to the block. Is there any market for used LS1 blocks? The block, crank, and heads all look great. Any idea what they would sell for? I was planning on rebuilding the engine but I've decided to go back to college so I could really use the money. I already have a new 402 in the car.
Old 07-28-2008, 01:02 AM
Coonass350's Avatar
pics of the 402!!
Old 07-28-2008, 01:46 AM
Cchris1109's Avatar
an experienced reputable tuner would have made it last :'(
Old 07-28-2008, 04:25 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Thats too bad.
Old 07-28-2008, 06:22 AM
CamaroSS19's Avatar
Thats what happend when you reach the limits of the stock shortblock stop blaming the tunner
Old 07-28-2008, 11:11 AM
02NBMFormula's Avatar
welcome to the dead piston club!
shouldnt there be a black coating on the sides of the stock piston??? or did they do that for different years?
Old 07-28-2008, 02:13 PM
ZDOG's Avatar
lol! thats excactly what my # 7 looked like.
Old 07-28-2008, 02:22 PM
landonew's Avatar
sucks man. I would think that the F/S section could net you some $$$ but not a whole lot. Might cover a semester or twos worth of books.
Old 07-28-2008, 02:24 PM
11psi with a cam and full exhaust probably was pushing the limit of the stock shortblock. That is why I asked if it was detonation that caused the ring land failure.
I'm the one that tuned it so I haven't been blaming anyone else for it
Old 07-28-2008, 02:26 PM
Sawzall and Welder Mod
Whistler's Avatar
04 LS1 and 02+ LS6 got the piston skirt coating
Old 07-28-2008, 02:50 PM
less10's Avatar
Broken ringlands usually result in too much fuel, or just simply making too much power.
Old 07-28-2008, 02:53 PM
are you 100% on that? this is the piston i pulled out of my 02 formula
the black stuff is the coating your talking about right???
Old 07-28-2008, 03:10 PM
Rickys S/C Z28's Avatar
pm me on what you want for the block
Old 07-28-2008, 03:24 PM
jeffboy757's Avatar
heres what happens in 7 psi NON intercooled with a crappy tune
Old 07-28-2008, 06:12 PM
CamaroSS19's Avatar
Its not your tune .Stock stuff just brakes form the extrem forces that were put on the piston
Old 07-28-2008, 11:57 PM
STAR's Avatar
I'm curious as to why too much fuel would cause broken ringlands? I was under the impression that either detonation or running lean would cause that kind of damage. Too much fuel would would run rich and cool the intake charge and is what most recommend when tuning. Am I missing something here?
Old 07-29-2008, 07:53 AM
geeteego's Avatar
Excessive cylinder pressures + heat + lean mix + detonation = bye bye #7.
It's the Perfect Storm of engine disaster. At least you didn't crack the block.
Old 07-29-2008, 09:50 AM
blacksi's Avatar
Why is it #7? I bumped a little lean the other day and sure enough melted the 7 spark plug. I have an 8 AN feeding in to the #7 first I thought this would get rid of this issue but it didn't.
I've thought about flow mapping some injectors and putting a slightly larger one in that hole.
Old 07-29-2008, 11:38 AM
lt170chevelle's Avatar
cant you just fine tune your individual cylinder fuel table? or is there not one in the ls1 tuning programs?
Old 07-29-2008, 01:14 PM
There is no way to do that with the stock computer and the tuning programs we have for these cars.
Quick Reply: Stock shortblock + 11psi + novice tuner...results inside
