Race Proven Motorsports 370cu in. D1SC Results
Old 07-30-2008, 06:16 PM
Frans96SS's Avatar
Thumbs up Race Proven Motorsports 370cu in. D1SC Results
2000 Trans am with 12k miles on it.
RPM Built 370 cu in, iron block.
PRC LS6 Heads
RPM Blower cam
stock ls6 intake and tb
Spec twin disc.
Steel DS
12 bolt with 3.55 gears
Nasty Sheet metal tank with A1000 pump
On 7.4 psi it made 575rwhp and 525 tq on a mustang dyno.
Im pretty happy with the numbers. More boost and meth numbers soon.
Ill post graph tomorrow.
Old 07-30-2008, 06:58 PM
forcd ind's Avatar
which a1000 pump were you using, the fi one or the carb one, or are they both the same? when i built mine, i used the a1000 in mind if i switch from carb to fi, i could just switch regs, i had hoped
great #'s, what were the afr's
Old 07-31-2008, 02:14 AM
BLK,97,T/A,M-6's Avatar
Good work Fran. I know Jeremy will be happy with the car, Especialy once the meth kit and little pulley go on. -Chris
Old 07-31-2008, 09:42 AM
Frans96SS's Avatar
as far as i know they are the same.
He will be happy.... i think he thinks its gonna be slower than it will be... but it feels great.
Quick Reply: Race Proven Motorsports 370cu in. D1SC Results
