Turbo oil drain in pan location?
Old 08-04-2008, 11:23 AM
chopperloco's Avatar
Default Turbo oil drain in pan location?
I'm ready to have a -10 alum. fitting welded into the pan.
Based on all of you experiance with a C5-where would you consider the best location to be on this pan.
Dominic
Old 08-05-2008, 02:03 AM
DeltaT's Avatar
Can't tell you but don't let anyone talk you into a spot where the drain is below the oil surface in the pan. It must drain above the oil sump level.
Jim
Old 08-05-2008, 06:42 AM
veee8's Avatar
Mine is located in the timing cover. See here....
Old 08-05-2008, 11:47 AM
Default Thanks...
...again.Dominic
Old 09-26-2008, 01:36 AM
loweredd's Avatar
Do you have anymore pictures of the timing cover location? I thought about this on mine, I guess it can be done.
Old 09-26-2008, 09:22 AM
veee8's Avatar
Here you go
And a fun one!
Old 09-26-2008, 12:54 PM
loweredd's Avatar
Holy cow. Nice. Thank you!!
Quick Reply: Turbo oil drain in pan location?
