Submersible injection hose, PCV coated wire, Y block
Old 08-09-2008, 12:47 AM
Black01M6SS's Avatar
Default Submersible injection hose, PCV coated wire, Y block
I know this is the wrong section for this but my thread in the Fuel & Injection section has gotten very little traffic and I'm kind of in a hurry to get this done. Mods please let this stay for the weekend at least. I figure this is the second best place to post it because most of the dual pump guys are using forced induction.
First off it is hard for me to believe that everyone installing a Walbro is using the correct submersible fuel injection hose. It is damn near impossible to find SAE 30R10 hose. I've only found it on a couple websites ranging from 20-23$ a foot + shipping. If anyone knows where to get it cheaper please let me know.
I've found a few Y blocks but they are all really expensive. From what I've seen so far it looks like I'll be paying around 50$ with shipping for a 5/16" Y block. If anyone knows where I can get a cheap Y please give me a link.
I have yet to find any wire that says if it is coated with PCV or rubber. I've looked at the local parts houses and Walmart. I've found plenty of wire but it doesn't say what it is coated with
Come on guys, help me out here. I know some of you guys have done this before. Did you guys just use normal fuel injection hose and normal wire?
Old 08-10-2008, 03:47 PM
back to the top
Old 08-10-2008, 04:15 PM
trans2000am's Avatar
id contact lonnie
Old 08-10-2008, 04:26 PM
frcefed98's Avatar
contact http://www.nastyperformance.com/
He should be able to set you up with everything.
Moroso makes a cheap Y block....and few guys used something from home depot if I remember right....it was a 3 way air hose coupler made of aluminum.
Hope this helps.
Old 08-10-2008, 04:43 PM
Derek @ EDO's Avatar
I used standard wire on mine and never had a problem.
NAPA sells the correct hose.
As far as the Y fitting PM me, I might have something that will work just fine for you.
Quick Reply: Submersible injection hose, PCV coated wire, Y block
