OKAy guys what am i doing wrong! No boost on my gauge!
Old 08-14-2008, 09:34 AM
T/AWS6969's Avatar
Red face OKAy guys what am i doing wrong! No boost on my gauge!
IS there something ia m doing wrong? I am not getting any boost reading(?) I attached the vacuum at the passenger side check valve and tee d it then ran the line under the cowl to another tee where the line comes from the Proflow ( made sure its not backwards) and then to the boost gauge inside the car. see pics--Thanks---Alan
Attached Thumbnails OKAy guys what am i doing wrong! No boost on my gauge!-0813082127.jpg   OKAy guys what am i doing wrong! No boost on my gauge!-0813082128.jpg
Old 08-14-2008, 11:22 AM
T/AWS6969's Avatar
10 views and no reply???
Old 08-14-2008, 11:30 AM
Todd157k's Avatar
pull the line from the boost gauge and put your finger on the end of it. Start it and feel if there's actually vacuum. If not, you pinched a line or broke it open, or something. If there is, then check your gauge itself. Put a hose on it and blow into it.
Also check those plastic T's. They break/crack easily.
edit: Check valve? wait a minute... you're not hooking it up to the pvc vent line are you?
Old 08-14-2008, 11:38 AM
Photochop's Avatar
Yeah make sure its not crushed or cracked anywhere. I T'd mine off of the ventilation vacuum port that comes off the passengers side of the brake booster vacuum fitting on the back of the intake manifold. Might try switching your source to there.
Old 08-14-2008, 11:56 AM
T/AWS6969's Avatar
well i hooked it to the check valve on the passenger side. in the procharger instructions it says to hook that to the check valve along with the FMU(?), which the FMU is not included in this kit. But the gauge is reading 18 ish vacuum at idle tho. just no boost when i rev it up. i would rev it to 4 grand and the needle on the boost gauge only goes down to about 5 to 10 on the vacuum, but no boost at all.
Old 08-14-2008, 12:04 PM
SpaZMaN's Avatar
You sure its actually making boost? Stupid question i know.
Old 08-14-2008, 12:09 PM
T/AWS6969's Avatar
when i twist the throttle body and rev from the front of the car i can see the procharger box pressurize with air so i know that there must be some boost.
Old 08-14-2008, 12:10 PM
T/AWS6969's Avatar
Old 08-14-2008, 12:40 PM
ls 2 goat's Avatar
Not gonna register boost just reving the engine..drive it and put a load on it..Jeremy
Old 08-14-2008, 12:51 PM
T/AWS6969's Avatar
Its not going to register boost just revving it? Sorry I'm new. " I'm new! I'm new, I dont know what to do !!"----Joe Dirt Thanks soooo much for clearing that up! I feel lika an *** LOL
Old 08-14-2008, 12:53 PM
ls 2 goat's Avatar
Hurry and erase it..I won't tell anybody..your like the 3rd guy this week I've had to help with this problem..Don't feel bad man..Jeremy
Photochop's Avatar
You're fine man. You should feel/hear the car beginning to pull harder and when the throttle is released you'll hear the air escape your BOV (whatever you procharger guys call it - BPV?)
Old 08-14-2008, 12:55 PM
ls 2 goat's Avatar
yup BPV...
Old 08-14-2008, 12:58 PM
T/AWS6969's Avatar
you guys are the best!!! Thanks!!!
Old 08-14-2008, 01:08 PM
ls 2 goat's Avatar
You can send me a fee of 5 bucks to my paypal...LOL..good to see you got it working man now go have some fun
Old 08-14-2008, 02:29 PM
T/AWS6969's Avatar
Thanks BRO!!!! I am so thankful to all my Brotha's on the Forum!!
Old 08-14-2008, 03:16 PM
MIGHTYMOUSE's Avatar
if you give it a good WOT rev you shoud definitely see it make boost
you are on the wrong side of said check valve
Old 08-14-2008, 03:25 PM
Todd157k's Avatar
Wait a minute... You can't hook to a check valve. The check valve will only flow in one direction... ie: vacuum in this case. When it's building boost, the check valve closes.
Find a manifold vacuum line.
I knew something was wrong with that whole "check valve" thing.
Old 08-14-2008, 04:09 PM
Monello's Avatar
You are able to test gauges or wastegates by hooking them up to a compressor. =)
Old 08-14-2008, 05:20 PM
T/AWS6969's Avatar
soooooo.... the check valve is totally a no no? Should i hook it to the brake booster line (vacuum)??
Quick Reply: OKAy guys what am i doing wrong! No boost on my gauge!
