Which block ?
Old 08-15-2008, 05:54 PM
stevieturbo's Avatar
Default Which block ?
Out of interest....what is the best value block out there for a base FI motor ??
I see LS6, LS2, LS3, L98, LS7.....what is the difference with them all ????
At what point does bore size compromise head gasket sealing ?
Old 08-15-2008, 07:04 PM
01ramair500hp's Avatar
all depends on the power you want to make, and also the amount of money you have to spend.
Old 08-15-2008, 08:12 PM
circa 1000, hence asking best value.....
No Iron.
Are the LS2, LS3 and L98 etc just the same, but a different bore size ?
Old 08-16-2008, 05:59 AM
TT-TECH Veteran
Inspector12's Avatar
The L92 Block seems to be best deal to me stronger in the manis and its a little bigger bore than a stock LS2??? GL its your choice.
Quick Reply: Which block ?
