GM6 Turbo from diesel....Cheap FI?
Old 08-17-2008, 03:15 PM
UNmolestedTA's Avatar
Default GM6 Turbo from diesel....Cheap FI?
I noticed a turbo diesel in a 98 dually the other day in the junkyard. Just curious if this turbo would be cost effective FI. My second question would be what kind of boost can I expect from this turbo? Background info: LQ4/LQ9 dropped into a 73 camaro backed by a th350. Thanks.
Old 08-17-2008, 04:39 PM
Silver_TransAm's Avatar
lol that sig is hilarious I remember that episode!
I dont think that turbo would wrk IMO because it is designed for a 6l engine that only revs to 4k tops. I dont know for sure though sorry.
Old 08-17-2008, 04:46 PM
Thanks for the reply. With the engine revving only to 4k on the diesel it would not last to 6k on a 6L?
Old 08-17-2008, 04:52 PM
well it would make a **** ton of boost I guess??
Old 08-17-2008, 04:57 PM
LS1TECH Sponsor
DrTurbo's Avatar
Boost will quickly spike and then drop FAST. To small a turbo...
Old 08-17-2008, 05:00 PM
Thats what i meant..
Old 08-17-2008, 05:02 PM
Phoenix 5.7's Avatar
the holsets off of the dodges have been used in some budget turbo setups. some of them are rather big. not ideal but might work
Old 08-17-2008, 05:16 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
My friend has a turbo off of a semi in his car. It ran 10.96 at 138 the first time out. It's a95 mustang with a 370, stock 317 heads, and a TH400 no brake with a 1900 stall.
Details: http://lsxextreme.com/showthread.php?t=617
That turbo is too small, but you can find turbos off of diesels that work.
Old 08-17-2008, 06:02 PM
NemeSS's Avatar
a Holset H1E is T4 flange, has 3 in vband outlet, must remotw wg
they came on 5.9 dodge trucks
will support about 550hp
Old 08-17-2008, 07:22 PM
The turbo will not make enough boost during the power band of an LQ4 or Lq9? What size are the turbos off of these trucks?
Old 08-18-2008, 07:38 AM
lt170chevelle's Avatar
I would think that the turbo off that diesel would be fine.Usually diesel turbos are quite big, usually the only downfall on them are the bigger exhaust side housing. tend to be a little laggy.If in doubt, just get a holeset.....or two lol
Old 08-20-2008, 08:04 AM
Shinsetsu's Avatar
any info on the turbo? like what semi motor it came off of?
Old 08-20-2008, 09:01 AM
Sluggish's Avatar
Boost doesn't matter it's just a number of the amount of resistance that is in the intake. He is saying that the turbo will not put out enough air for the motor.
Old 08-20-2008, 01:12 PM
OWN3D BY MY PROF!
We don't really know too much about it. He got it for free from a friend that was scrapping a semi. All we know is it's an Air research unit with a T6 flange.
Old 11-23-2008, 12:10 PM
crookedbowtie's Avatar
If it doesn't push enough air thats too bad he'll just have to install 2?
Old 11-23-2008, 05:51 PM
Big Bird WS6's Avatar
how about the HX52?
Quick Reply: GM6 Turbo from diesel....Cheap FI?
