how should spark plugs look with meth injection
Old 08-18-2008, 10:05 PM
BigRich954RR's Avatar
Default how should spark plugs look with meth injection
Ok 6 liter ls2 with 11 psi of boost ive been tuning with wideband a/f gauge i pulled out alot of 91 octane gas from the tune and added alot of meth injection.
A/f is holding from 11.5 to 10.8 at max boost.
meth nozzle is a 15 gph at 100psi off hand i start spraying at 60 psi to 180 psi at readline so thinking the nozzle is flowing alot more then 15gph.
How should the plugs look when running meth?
I will soon be running 2 15 gph nozzle will add twice as much meth will it change how to read the plugs any?
Old 08-21-2008, 02:57 PM
Ok pulled plugs out after 5 1/4 miles runs center tip looks clean and ceramic center look clean as new white. the out side ring where threads stop and its just the metal ring sticking in chamber is a very little blacken the ground strap is looking like a dirty ish white yellow color.
Try to get a idea what this means?
Quick Reply: how should spark plugs look with meth injection
