403 and D1SC Pulley combo for 12 psi.....
Old 08-21-2008, 07:53 PM
helicoil's Avatar
Default 403 and D1SC Pulley combo for 12 psi.....
I have a D1SC and was looking for a pulley combo with the SDCE set-up that would get me in the 12 psi mark, erroring on the high side, as I don't want to change it if not necessary in the immediate future and want to hit my goals right out of the gate.
I know there are lots of variables but surely someone has run similar parts as this is a fairly common build.
403, AFR 225, 9.5:1, 232/240 @ .050 115 lsa in at 0, 1 7/8 tubes, catted Y and Magnaflow rear cat back. I am also using the twin 4.5"s coolers and the FAST 90/90 set-up with the BIG air filter and stock plastic ATI hat.
I have a 7.250" crank and a 3.55 and 3.70 supercharger pulley to play with. Engine RPM will be 6300-6500 tops.
thanks
Old 08-22-2008, 04:45 AM
EPP
EPP's Avatar
Angry
thanks
KP might be able to nail this one down for you, as he has used the SDCE bracket assembly for many years. I would say it will take the 3.55 with your mods. Bob
Old 08-22-2008, 06:48 AM
helicoil's Avatar
Thanks Bob, I thought that might be the one.
Old 12-09-2008, 03:50 AM
firehawk618's Avatar
I'm running 3.45 blower pulley and saw a max of 10.5 with some belt slip at the higher rpm's.
Running almost same setup as you except LS6 intake.
Old 12-09-2008, 01:06 PM
helicoil's Avatar
Yeah with my set-up and the 3.55 (heads, cam, exhaust, etc.) and no slip, I seem to be making 9#
Old 12-09-2008, 01:41 PM
lmt0705's Avatar
the SDCE has a smaller crank pully though so you will have to go even smaller on the blower pulley.
Old 12-09-2008, 08:56 PM
Forced370GTO's Avatar
by the calculations, assuming the graph of flow vs rpm is linear, you should see 8.75 psi but that is very dependant on your particular setup
Old 12-09-2008, 08:57 PM
that was with the 3.55 pully
Old 12-10-2008, 08:59 PM
helicoil's Avatar
Well, I got 9 with the 3.55, so that is pretty darn close. How did you figure it?
Old 12-10-2008, 09:22 PM
F1C YA's Avatar
Listen to Bob he knows what he's talking about........
Quick Reply: 403 and D1SC Pulley combo for 12 psi.....
