Procharger plenum cracked again...
Old 08-22-2008, 10:21 AM
Packy's Avatar
Default Procharger plenum cracked again...
Well my plenum has cracked for like the 4th time. So I think instead of welding it again I just need to get a new one. Does anyone have a metal plenum for the F-body kit laying around that they don't need anymore. I would really like to get a polished plenum too if someone has one. Please pm me so we can work out the details. Thank you.
Old 08-22-2008, 11:45 AM
AFASTYZFR1's Avatar
Just weld it up.....the box is not the problem.....you need a better bypass
Check out my thread when my box blew up
https://ls1tech.com/forums/forced-induction/949284-plenum-box-exploded-procharger-race-bypass-info-needed.html
Old 08-22-2008, 06:31 PM
Packy's Avatar
Yeah but i have welded it 3 times already and it keeps breaking. I will have to look into that.
Old 08-22-2008, 07:13 PM
Blackbird's Avatar
get rid of it and do a Y setup.
flows better, no broken boxes.
procharger will sell the Y for a very reasonable price and then you just have to come up with a little custom tubing on your own.
we did this on my buddy's car is it's way better than the crappy box ati uses.
Old 08-22-2008, 07:19 PM
Packy's Avatar
Anyone got a picture of it. It sounds like it is better.
Old 08-22-2008, 07:58 PM
Zeke34's Avatar
+1
Old 08-22-2008, 09:23 PM
LS1Tech Sponsor
Slowhawk's Avatar
I prefer running a TIAL blow (with the stock ATI bypass) .Not a fan of the ATI race valve and how loud it is cruising. The TIAL with the 11lb springs needs 16" of vacuum to open.Perfect to take the pressure off the pipes.
Old 08-22-2008, 09:47 PM
AFASTYZFR1's Avatar
But after it broke the first time did you change the bypass?
The only reason the aluminum plenum will crack is if the bypass cannot vent the air out quick enough.....the air has to go somewhere if the tb is closed....since you have cracked the plenum multiple times you need a better flowing bypass to release the pressure better
Here is a pic of the y set-up though
Old 08-22-2008, 10:05 PM
Packy's Avatar
Yeah, I had changed to the ATI Race valve after the second time. Oh well maybe I will look at it again and throw a Tial on there as well.
Old 08-22-2008, 10:07 PM
AFASTYZFR1's Avatar
How much boost are you running?
Old 08-22-2008, 10:12 PM
Packy's Avatar
8 psi...
Old 08-22-2008, 10:18 PM
AFASTYZFR1's Avatar
with an ati race bypass (red one) you should not be cracking the aluminum plenum....I am running 16psi through my aluminum plenum w/ ati race bypass
maybe bypass needs adjusting.......or isn't working properly
Old 08-23-2008, 02:48 AM
Rickys S/C Z28's Avatar
man just go with a FMIC and be done with it
Old 08-23-2008, 01:18 PM
wildta's Avatar
EPP has a kit !!
Old 08-23-2008, 01:33 PM
yep thats the one i have and i love it!!
Old 08-23-2008, 01:35 PM
helicoil's Avatar
Wow, thats alot of hose clamps righ there!
Old 09-10-2009, 10:30 PM
spaz1's Avatar
Mine also cracked 2 times. I didn't think I needed to run a bypass at only 8psi. It's wierd that the rubber hoses arn't blowing up. I think a y setup would work nice. Probably faster spool too.
Old 09-10-2009, 11:11 PM
'Trust''s Avatar
I had the bottom part of my plenum replaced with a 1/4" thick pierce of aluminum and haven't had any problems since. TiAL BOV in the pipe between the TB and Plenum.
Quick Reply: Procharger plenum cracked again...
