oil feed and drain line sizing and a restrictor?
I have a majestic 88mm turbo. Should I run a -3 or -4 feed line? Also, will I need to run an oil restrictor? Should I run a -10 or -12 drain line?
I run a -3 equivalent steel line on my tubonetics 78mm with a -10 return & never have had any problems. A lot of people here have had to use restrictors but I noticed it is with -4 feeds which is the size most everyone uses.
