I'm really tight on budget now and thus the question - is it really necessary, or boxing the housing in nice shiny polished steel box would do the trick? Or maybe just wrapping the housing with a headers thermo tape?
It's not a requirement to run a blanket, just do it to reduce under hood temps and increase the efficiency of the hot side of the turbo to help spool quicker.
You don't want a gap between the turbine housing and another object if you're trying to retain heat.. you don't want any heat dissapated, which is the point of a blanket, to contain the heat. A metal box WILL work more as a heatsink vs the blanket.
I thought if it wouldn't touch housing, it wouldn't work like a heatsink. And if it's polished inside, it would keep the heat inside. Or am I talking BS?
I would say if you want to go the box route to perhaps sandwhich some of that aluminized insulation pads between the steel plates, but by then you're getting near the $ of a blanket.
