sts questions
You can run a blow through setup, which is what I think you mean by no computer. Not hard to put together, I fabbed my rear mount myself, and it worked great. STS' universal systems look pretty complete, but if you're going to spend the $, you might want to consider building a front mount, if you've got the rom.
1 Post
The key for carburation + FI is getting enough fuel in the combustion chamber under boost to prevent detonation w/out overloading it w/ fuel during part-throttle operation. Can be done (lot of bad-a$$ed Weiland supercharged cars on the road), but youll be spending a lot of time calculating and changing jets.
Should be pretty darn sweet once done. Good luck.
