Turbo to small?
Old 08-31-2008, 11:05 PM
WSsixed's Avatar
Default Turbo to small?
Ok so i orderd a hp performance stage 1 turbo kit for my 99 WS6 about a month and a half ago. But i have been thinking the turbo seems kinda small. The turbo is 60mm with .96 A/R, what do you guys think? Should i sell this turbo and get a bigger one? What do you think of the turbonetics 850 gtk? Or what sizes can you suggest?
Thanks for any input!
Old 08-31-2008, 11:27 PM
kbracing96's Avatar
Depends on how much power you want to make. That turbo will be good to only about 500 rwhp.
Old 08-31-2008, 11:36 PM
WSsixed's Avatar
well id def like to get around 500 rwhp on a safe level of boost.
Old 09-01-2008, 12:05 AM
TurboZ28408's Avatar
i personally like my Masterpower T70, setup is currently making 525 at 9 psi
Old 09-01-2008, 12:54 AM
Sammyboy's Avatar
I have an excel file that will calculate your pressure ratio and corrected flow assuming 100% volumetric efficiency so that you can plot on a compressor map and find the turbo that will fit right for you. pm me your email address and I'll send it to you.
Old 09-01-2008, 01:02 AM
MDoe8's Avatar
For a stock motor that turbo will be fine. Not to mention, it shuold create some killer torque with it's faster spool!
Old 09-01-2008, 02:02 AM
WSsixed's Avatar
Are you on a stock engine?
Old 09-01-2008, 02:05 AM
WSsixed's Avatar
I hope so! What kind of power could i expect from 7ish psi?
Old 09-01-2008, 02:11 AM
cracker's Avatar
The backpressure on that kit will be through the roof!
With 346 ci. go with at least a Precision 62mm with a decent exhaust housing. HP's kit uses 2.5" charge pipes and a 3" downpipe. If it were my car, a 67 HPS series turbo would be a incredibly fast spool and make more power than the Turbonetics unit while saving space.
67mm Precision with a .68/.81 exhaust housing, "S" Cover (compressor) - 4" inlet 2.5" discharge.
Stay away from the off the shelf Garrett turbos HP uses.
Oh yeah, be prepared to wait on HP. The are the slowest most procrastinating people on the planet. Yes, many personal experiences...
Old 09-01-2008, 11:59 AM
kbracing96's Avatar
I think that turbo will be fine for your car with a stock motor and all. It will spool quick and be fun to drive. That's how I like my street setups. The compressor is a little on the small side, but your back pressure won't be bad with that .96 A/R housing. Give it a try, you can always upgrade later.
Old 09-01-2008, 02:25 PM
WSsixed's Avatar
yeah I got the feeling I'd be waiting forever on them seeing as it has already been longer then they said it would be. And now they say mid September
Old 09-01-2008, 02:28 PM
WSsixed's Avatar
that is very true lol. What kind of power should I expect from 7psi on this kit?
Old 09-01-2008, 02:29 PM
52172's Avatar
You should of never bought a turbo from HP they are terrible.
Old 09-01-2008, 02:42 PM
bboyferal's Avatar
Are you guys sure a 60mm can hit 500 rwhp?
Old 09-01-2008, 02:50 PM
jschmidt33's Avatar
go with an 88 baby!
Old 09-01-2008, 02:52 PM
kbracing96's Avatar
I have done it on a 4x4 truck with a 4.8
Old 09-01-2008, 03:09 PM
WSsixed's Avatar
Yeah i kinda got that feeling, are the kits good or is it just the customer service that sucks?
Old 09-01-2008, 03:30 PM
bboyferal's Avatar
Did it do it easily or running out of steam?
4.8 and 5.7 is a significant difference, too, further pushing that turbo closer to inefficiency...
I've just never hear of someone hitting 500 rwhp with a 60mm on a stock 346...
Old 09-01-2008, 03:40 PM
xxxhp's Avatar
-Go with atleast a 76mm turbo. You'll thank yourself later
-I never had any problem with HP, both their turbo kit & their customer service were fine with me, and I live overseas!
Old 09-01-2008, 03:47 PM
WSsixed's Avatar
Well thats good to hear! How long did your kit take to build and ship?
Quick Reply: Turbo to small?
