turbo gearing
Old 09-04-2008, 07:30 PM
ms4z28's Avatar
Default turbo gearing
I have 4.10 gears in my car right now and I have a lq4 turbo in my camaro not quite done yet but would it be better if I got 373, 342, or leave the 410 it's an auto and most of the time going to have 17 inch drag radials
Old 09-04-2008, 07:51 PM
30th t/a's Avatar
3.08s, 3.23s, 3.42 or 3.55s are what you want. These make the engine work harder which builds boost quicker. 4.10's suck for a turbo car.
Old 09-04-2008, 07:54 PM
LS1Formulation's Avatar
Look at turbo Buicks - even the fastest stock suspension cars still use stock ratio 3.42 gears. Turbos build so much low end power, you don't need a low gear set like a 4.10.
Old 09-04-2008, 09:54 PM
Mike 01WS6's Avatar
I'm looking at possibly changing my ratios slightly. My A/R on my turbos is getting cranked up from a .63 to a .86.
I run a stock 3.42 cog, I'm looking to turn it down to a 3.33 or 3.23 to help the spool I'll be losing. Figure high 600's at the tire on pump and 850+ to the ground on race gas. I wonder the ratio change will be worth it or not.
Old 09-05-2008, 10:28 AM
ms4z28's Avatar
thanks thats a lot of help
Old 09-05-2008, 01:23 PM
67Firebird455's Avatar
Had 4.10's with a 6 in my 99 TA I had. Didn't build boost on the *** mount until like 3rd gear... could get a couple lbs in 1st, like 4 in 2nd, and could get 8 in 3rd.
Old 09-05-2008, 02:14 PM
Public's Avatar
Damn that's bad, did you ever try a diff gear in it, have headers? Was spooling the base T60 by 2400rpm and a GT70 by 2500rpm boosting nicely with both by 2800 and 3000 on a stock M6 car with MAC Y with 60lb motorons.
Old 09-06-2008, 10:32 PM
AKAFRED's Avatar
i went from 3.73 to 3.42 on my turbo car and it seems to work far better.
Old 09-10-2008, 10:14 PM
fenix999's Avatar
get 3.23's in a 6-speed car and 2.73 if its automatic. You will thank me later from the amount of MPH you pick up in the 1/8, 1/4 and just about any and everywhere!!! TRUST ME DO ITTTTTTTTT!!!!
Quick Reply: turbo gearing
