What PCV valve do you use?
I still have the PCV hooked up stock style (to the valve cover, no LS6 valley cover) going to the intake manifold with a catch can. I thought I might replace the PCV valve as maintenance. I know some guys just use a check valve and no PCV, but didn't know if that would be too much vacuum? Looking for advice on what to use.
Thanks!
Thanks!
hmmmmm
Sam have you looked inside the intake with your setup know to see if you got oil! I understand what you where telling me lastnight about how you have it hooked up , but i just cant believe you are not oiling the hell outta the intake! Lotta go post on here about the whole system!
No oil in the intake at all. I do have a oil/air separator though.
