Should I wrap my ceramic coated Hot parts?
Old 09-09-2008, 02:14 PM
JerikSS's Avatar
Default Should I wrap my ceramic coated Hot parts?
Like the title says, should I? Will be an added benefit or will the ceramic coating be enough??
Old 09-09-2008, 02:21 PM
ninetres's Avatar
You will hear people say it is not good to wrap it because it wll deteriorate.....but I am about to wrap mine. My underhood temps are just too hot.
Old 09-09-2008, 02:23 PM
abbaskhan's Avatar
any way you can reduce heat helps
i do it on the cars i work on
it helps to the point where i can put a hand on the header primary and not get burned like i used to
and this is on turbo car
Old 09-09-2008, 02:38 PM
Photochop's Avatar
I wrapped my crossover and downpipe right after I had them blasted/recoated.
Old 09-09-2008, 03:05 PM
1INSANEGTO's Avatar
I thought this can also help spool time. I plan to coat my outside and inside plus wrap.
Old 09-09-2008, 03:06 PM
slomarao's Avatar
up to you. Some will say never, others always do.
Old 09-09-2008, 05:08 PM
Grr
Grr's Avatar
definately
Quick Reply: Should I wrap my ceramic coated Hot parts?
