TC78 Downpipe size??
Old 09-10-2008, 12:28 PM
Skelbow's Avatar
Default TC78 Downpipe size??
Been trying to do a search and find the answer, but I can't find any info.
What size is the downpipe for these turbos?? 3.5"?
Thanks!
Old 09-10-2008, 12:46 PM
LS1Tech Sponsor
hellbents10's Avatar
3" v-band on the turbine housing.
Old 09-10-2008, 01:17 PM
LS1TECH Sponsor
DrTurbo's Avatar
Yup...3" indeed.
Old 09-10-2008, 05:24 PM
1CAMWNDR's Avatar
Any need to use a 3.5" DP on say a 400ish inch motor? Say.......15psi max?
Old 09-10-2008, 06:39 PM
SPRAYED 01's Avatar
Im running a 3inch on mine. I also wonder if a larger down pipe would help out at all. I would imagine its hp ratings are with a 3inch.
Old 09-10-2008, 07:06 PM
bluecamaroz28's Avatar
What is the criteria for selecting down pipe size?
Old 09-10-2008, 09:07 PM
HitmanLSX's Avatar
probably the outlet on the exhaust side of the turbo
Old 09-10-2008, 09:52 PM
fenix999's Avatar
3" is fine, downpipe size required should be whatever the turbine housing is and nothing less than that. 3" is what it is, so 3" is what you should use, anythig bigger will be wayyy more expensive and be a pain in the butt for clearnance. Guys with a T6 turbo will obviously need bigger downpipe options, but most T4's are simply 3.0"
Old 09-10-2008, 10:27 PM
Josh@KY-Turbo's Avatar
Exactly right.
Old 09-10-2008, 11:00 PM
Skelbow's Avatar
Thanks guys!
Old 09-11-2008, 01:40 AM
engineermike's Avatar
I've heard a general rule that you want the downpipe to be 1.25-1.5x the turbine exducer. That would mean a minimum of 3.5" for the TC78. However, as long as the pipe is at least as big as the exducer, you're not giving up a lot of power.
I'm running a 3" downpipe on my T76GTS (2.96" exducer) and it works reasonably well, though I do think I could gain some power if I upgraded. I do know that a 3" downpipe is good for 140++ mph in the quarter, maybe even 150.
Old 09-11-2008, 07:24 AM
Photochop's Avatar
I'm not sure if its anything to do with my exhaust change, but when I first got my car together back in mid July, I ran around with a 3" open downpipe that stopped at the firewall. I drove the car a few days like this and it was bogging alot, loading up, etc.
I wanted a reasonably quiet exhaust but didn't want to restrict it. I ended up using a couple of reducer cones backwards that I had sitting around from a previous build, and went from the 3" outlet of the downpipe up to a 4". I had the exhaust shop weld in an old 4" dynomax 12" bullet where the stock cat goes (another old piece I had lyin around) and bought 2 - 4" mandrel 'S' bends and had them cut and welded up to tuck the 4" pipe up tighter into the tunnel. I'd bought a 6" round 4"in/out magnaflow muffler and had that welded up just under the backseat area with a turndown.
I swear the car ran 10x better with the exhaust on it. That may have been largely due to the car 'learning' the tune that had been loaded into the PCM prior to startup (mainly for the 60lb injectors I'd swapped to), but the car seemed to spool faster and build boost quicker with the exhaust on. The car sounds great, very deep and throaty, really alot like an LT1 actually. Its not too droney for a dumped exhaust, you can carry on a conversation in the car and not have to raise your voice any.
Heres the best pic I have of it...
Old 06-18-2009, 09:00 PM
Vetal's Avatar
I'm going to run short downpipe (3ft) out the side of the bumper. Is 4.5" DP going to be fine to extract most from TC78? Or will it give absolutely no gains over 3.5" or 4" downpipe?
Old 06-19-2009, 07:47 AM
pwrtrip75's Avatar
this post is from last year...lol. But depends on how many bends. If you calculate how a straight peice of pipe flows, each bend will add so many feet of pipe to the flow characteristics. Example. A peice of 3" pipe (straight) might flow the close to a 4" pipe with 4 bends in it. Im not sure the exact formula, every pipe and bend would be different.
Old 06-19-2009, 08:58 AM
Rule of thumb... keep gas velocities below 200 ft/sec. If you do this, the piping losses will be low. There is an exponential rise beyond that.
Old 01-14-2014, 10:05 PM
ls1bumblebee's Avatar
obx 4'' downpipe here
Old 01-14-2014, 10:16 PM
Chris@CBR's Avatar
Holy knock the crust off a old thread BatMan!
Quick Reply: TC78 Downpipe size??
