What turbo for 408 rearmount?
I want to make about 800rwhp. I have a 408 rearmount turbo with a t70. Its a 6spd. its making about 625rwhp at 8psi right now. How would a st76 work? Or would a gts76 work better? Or should i go bigger? Ive looked around theres not much info for rearmounts making this much power so i would appreciate your input.
^ i know a few rear mounts that make power in that ballpark.
my goal is 500-550 rwhp (with bone stock ls2) and will be using
either a gt60 or gt67. at @ 8 psi
so my guess is your on par with your goal...
any pics of your setup? and good luck!
We used a 76GTS on a 408 butt mount car, it had a .81 EX housing. The top hp number was right around 700rwhp on 11#.
Spool was somewhat an issue, boost came on around 3800-4000. This was majorly due to having the SLP long tubes and a full 3in exhaust.
Going to a 4in downpipe made a huge diffrence though. Even though its a small run, the stocker 3in was a big restriction.
How would the st76 fit in the back due to its larger size? How musch biggers is int then the 76gts. What ar would guys recomment its about 98% street 2% track? & no i dont have pics yet. i have fmic with no meth but the meth will go back on soon.
So ive been hearing about a bunch of 76 trims. which would be better for my application & y? 76gts, gt42 76r, st76, or a tc76 or tc78. is there much difference between these? which 1 would you choose & y? i just dont want to run out of effiency towards the top
