oil drain scavenge pumps
Old 09-21-2008, 03:22 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
Default oil drain scavenge pumps
I've been reading around, and think I might need one.
I see Tilton, Mocal, CarterRace and this one:
http://www.rbracing-rsr.com/oilsystems.htm
discussed on a few boards.
I'd have to run an electric one to get it done fast.
That article link is saying that some of the pumps that folks use are really not supposed to run hot oil.
So, what setups are guys running? I'll know for sure, but if I pushed out the front seal in the inlet side it would have to be an oil drain is my conclusion.
Thx budz
Old 09-21-2008, 03:39 PM
blacksi's Avatar
I'm running the rb pump. I've only got 3000 miles on it but seems to work fine.
Old 09-21-2008, 04:29 PM
kbracing96's Avatar
STS uses that same pump as the RB. I had 2+ years and 40k miles on my STS kit when I sold it and the guy I sold it to is still running it. Seem to be a good pump.
Old 09-21-2008, 04:45 PM
venom ws7's Avatar
I was testing my car last night in 4th gear and the car started smoking I checked everything and it seems the scavenge pump stoped working or maybe it heated up
I changed the oil and the car is running fine again???
I'm running STS Pumps and only 15k miles on them.
Is my Scavenge pump dyning???
Sorry for going off topic John.
Old 09-21-2008, 06:44 PM
Vadian's Avatar
I used the Turbowerx scavenge pump for several months. Loved it. Just another option to look at. Google "Turbowerx"
Old 09-21-2008, 08:26 PM
bboyferal's Avatar
My Hi-Flo electric scavenger pump has been the only part on my car that has outlasted everything else, including a motor lol, for many years now, hot oil and all.
Old 09-21-2008, 08:32 PM
LS1Tech Co-Founder
Thanks guys.
Old 09-21-2008, 10:32 PM
extremetoy's Avatar
i got the weldon 9200a pump, havnt installed it, i hope it works good
Old 09-22-2008, 02:50 AM
WestSide's Avatar
I'm running an expensive Mocal one, and it has been absolutely GREAT. It comes with a metal mounting bracket that has rubber boots on it, to keep vibration and sound down.
I put a small reservoir under my turbo drain to pool all the oil up before it went into the oil pump, to help keep the oil from backing up into the turbo....the small reservoir was only $100 to have custom fabricated.
Old 09-22-2008, 07:29 AM
70Stang's Avatar
CarterRace!!!
Old 09-22-2008, 08:05 AM
TURBOPOWERED68's Avatar
Thumbs up
subscribed
Old 09-22-2008, 08:18 AM
RealQuick's Avatar
Subscribing... good post.
Old 09-22-2008, 08:33 AM
7 Second Club
Phil99vette's Avatar
I'm running a stock car dry sump and we've got no issues with blowing oil past the seals. It pulls the oil out and has a slight vacuum.
Old 09-22-2008, 09:28 AM
LS1Tech Co-Founder
Yeah I'm running a stock style oiling system (wet sump) so I don't know how it would compare to a dry sump.
Old 09-22-2008, 10:06 AM
brobards's Avatar
On my brothers turbo mustang we were running into problems with our original scavenge pump. We would have bad oil smoke during startup due to excess oil accumulating in the return line after engine shutdown. We switched pumps to one that was specicially designed for oil and put the scavenge pump on a turbo timer which switches off 10 seconds after engine shutdown and the problem is gone.
Old 09-22-2008, 10:23 AM
LS1Tech Co-Founder
My bud is going to leak it down for me, so we can see if that's an underlying problem. Was told if it leaks down bad, too much pressure is getting past the rings and into the pan, and pushing up thru the -10 drain line and then backing up the oil in the turbo... Sound about right? We'll see, the motor is a few years old but doesn't have a lot of passes on it. My friend said it was leaking from both seals so it could be that the engine is tired but I'll know by tonight.
If it leaks down decent, I'm still planning to buy an electric scavenge pump for the drain line and look at some basic things to help with vacuum.
Old 09-22-2008, 11:20 AM
qqwqeqwrqwqtq's Avatar
Still wouldn't think you would need a scavenge pump but I have a new electric pump and harness/fittings that was included with my APS system if you're interested.
Old 09-22-2008, 11:22 AM
Fireball's Avatar
vacuum pump...
I'm running a -12 return on mine...
Old 09-22-2008, 11:24 AM
Coal Mining Director
onfire's Avatar
I'd start simple since it's cheap. Fix the PCV first....it made a huge difference on my car....doesn't leak or weep around the turbos at all now. Doesn't take much crankcase pressure to back the oil up.
Old 09-22-2008, 09:38 PM
LS1Tech Co-Founder
I called around and did some research, and Kurt reccomended a -12 drain, and running a restrictor if the oil pressure is on the high side. Alex from PTE suggested checking to see if too much pressure is getting into the pan.
Sounds like the leak down numbers so far are not so hot.
Thanks for the offer Jim.
Quick Reply: oil drain scavenge pumps
