Slp oil pump which spring..?
Ok if you are running the slp pump are you running the high pressure spring ?
If so any problems. Figure since running a 408 should be running the higher pressure spring. Don't want to push oil out the turbos but guess can run restrictors if need be.
Is the high pressure spring that much higher than the standard..heard it was only like 5psi more??
Also did most of you still need to grind a bit on the cover like shown in slp instructions or did it fit fine. I realize you don't use the shims with the slp pump and double roller combo.
